Display Date Format
  • Display Date Format
    Posted by DSC Communities on September 9, 2020 at 2:48 am
    • Graham Birks
      September 9, 2020 at 2:48 AM
      I have a DataCardValue that returns a date using Parent.Default and it displays in US format mm/dd/yyyy. I want the date to display in dd-mmm-yy. I have tried to wrap a Text function around the Parent.Default but nothing seems to work. Disclaimer… I am new to PowerApps but tried to find the answers before writing here. Any help is appreciated.
      regards Graham
      Graham Birks
    • Mark Pearson
      September 9, 2020 at 3:05 AM
      In the properties to the field there is a selction called Format.Ā  You should be able to “dd/mm/yyyy” in that box and it will change the format.Ā  This surmises that it is a date field.
      Mark Pearson
      National Operations Manager
      61409321547
    • Graham Birks
      September 9, 2020 at 3:23 AM
      Hi Mark, thanks for your prompt response. Excuse my ignorance but I can’t find “Format” under “Properties” for the field??? See my screen shot. regards Graham
      Graham Birks
    • Graham Birks
      September 9, 2020 at 3:46 AM
      Hi I finally found a way to do this as follows…
      Text(DateTimeValue(Parent.Default),”[$-en-GB]dd-mmm-yy”)
      regards Graham
      Graham Birks
    • Mark Pearson
      September 9, 2020 at 5:24 AM
      The Format property is in teh dropdown next to the Function box.Ā  If this is not a date field then there will be no option.
      Mark Pearson
      61409321547
    DSC Communities replied 5 years ago 1 Member · 0 Replies
The discussion ‘Display Date Format’ is closed to new replies.
