Difference between columns with condition referring to another column
  • Difference between columns with condition referring to another column
    Posted by DSC Communities on August 31, 2022 at 4:48 pm
    Difference between columns with condition referring to another columnJump to Best AnswerFollow
    Mihai Stanca
    Mihai StancaAug 31, 2022 07:49 AM
    Hello Please help me with a DAX measure where i can calculate the values as described. Based on column …
    1. Difference between columns with condition referring to another column
    Mihai Stanca
    Posted Aug 31, 2022 07:49 AM
    Hello
    Based on column “Service type”, i want to make the difference between END DATE and INITIAL DATE, or END DATE – INTERMEDIARY DATE OR INTERMEDIARY DATE – INITIAL DATE and have the result into one column “Difference”
    = IF SERVICE TYPE is AAA1 than END DATE -INITIAL DATE && IF SERVICE TYPE = AAB4 than END DATE – INTERMEDIARY DATE…
    Thank you
    INITIAL DATE INTERMEDIARY DATE END DATE SERVICE TYPE Difference
    1/1/2022 3/4/2022 6/6/2022 AAA1
    1/12/2022 4/15/2022 6/8/2022 AAB4
    1/23/2022 4/27/2022 6/10/2022 ACD4
    2/3/2022 3/4/2022 6/12/2022 ADD9
    2/14/2022 4/15/2022 6/14/2022 AAA1
    2/25/2022 4/27/2022 6/16/2022 AAB4
    3/8/2022 3/4/2022 6/18/2022 ACD4
    3/19/2022 4/15/2022 6/20/2022 ADD9
    3/30/2022 4/27/2022 6/22/2022 AAA1
    4/10/2022 3/4/2022 6/24/2022 AAB4
    4/21/2022 4/15/2022 6/26/2022 ACD4
    5/2/2022 4/27/2022 6/28/2022 ADD9
    Mihai Stanca
    Acasa
    2. RE: Difference between columns with condition referring to another column Best Answer
    Kaz Shakir
    Posted Sep 09, 2022 07:34 PM | view attached
    @Mihai Stanca,
    If this is the only table you have, then I you just need to add a calculated column like this:
    Difference =
    SWITCH(
    Table1[ServiceType],
    “AAA1”, DATEDIFF(Table1[InitialDate], Table1[EndDate], DAY),
    “AAB4”, DATEDIFF(Table1[IntermediaryDate], Table1[EndDate], DAY),
    DATEDIFF(Table1[InitialDate], Table1[IntermediaryDate], DAY)
    ​And when you place that into a table visual, you get this:
    Hope that helps.
    Kaz.
    Kaz Shakir
    TN
    Attachment(s)
    pbixStancaExample_v1.pbix
    replied 2 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Difference between columns with condition referring to another column’ is closed to new replies.
