Delegation issue with ClearCollect
  • Delegation issue with ClearCollect
    Posted by DSC Communities on July 5, 2020 at 11:56 am
    • Enrique Carrasquillo
      July 5, 2020 at 11:56 AM
      Hi everyone,Ā
      First time posting here as I’m usually able to solve my problems from other’s posts. I couldn’t find any discussion related to this specific issue and I feel like I’m missing something obvious, so I’m hoping someone can shed some light…
      Situation: I want to collect all rows from a SP list (less than 500 rows). It is a simple list and I want to filter by a Number column so I shouldn’t have any delegation issues.Ā  My intention is to use the Collection to populate a Dropdown.Ā
      However, when the ClearCollect runs (onStart) it only returns one row (I have the limit set at 1 for non-delegable queries). No delegation warning shows anywhere. I tried populating a Gallery directly from the SP list and it works perfectly, all items are returned.Ā
      Items (Gallery): Filter
      (_SPlist, ShowItemsĀ = 1)Ā
      OnStart: ClearCollect(colRutas,Filter(_SPlist, ShowItemsĀ = 1))
      Thanks in advance for any help.
    • Mark Pearson
      July 5, 2020 at 3:49 PM
      Not sure what you mean you have the filter set at 1 for non delegable queries?Ā  Ā Do you mean you have changed the 500 to 1?Ā  You should note that the dropdown will never hold anymore that 2000 records (if the advanced has been changed to that) as this is the maximum records that can ever be returned at any time (delegable or Non Delegable)Ā
      In relation to the number column why use a dropdown?Ā  I would just use a text input with something like:
      If(isnumbe(TextInput1.Text),Filter(_SPlist, ShowItemsĀ =Ā Value(Textinput1.Text),SPList)
      Simply that will filter teh list based on any number or leave the list alone.Ā  You can add multiple textinputs and dropdowns to this approach to seach on more columns at the same time or individually)
      Mark Pearson
      National Operations Manager
      61409321547
    • Luke Burgess
      July 6, 2020 at 5:39 AM
      Hi Enrique,
      The ClearCollect command cannot be delegated when used with a data source, This is why the direct query to the data source is working and not the ClearCollect method.Ā
      See delegation section in
      https://docs.microsoft.com/en-us/powerapps/maker/canvas-apps/functions/function-clear-collect-clearcollect
      Is there a reason you have this set to 1? Alternatively you may simply have to run your query against the SP list rather than a collection.
      Luke Burgess
      SharePoint Administrator/Developer
      July 6, 2020 at 12:10 PM
      Thank you Luke. For some reason I did not see that note on the documentation and I figured I would get some sort of delegation warning in Powerapps if that was the case.Ā
      Only reason to have the limit set to 1 was to make sure delegation wasn’t an issue through the app. For this specific case changing it back to the 500 limit will solve my problem as that specific list will never reach that limit.Ā
      Thanks everyone for the help!
    DSC Communities replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Delegation issue with ClearCollect’ is closed to new replies.
