DAX Formula to restrict data
DAX Formula to restrict dataFollow
Ben Hopes
Ben HopesSep 06, 2022 06:48 AM
Please can someone help with a row level security query. I have the following tables Entity A …
1. DAX Formula to restrict dataBen Hopes
Posted Sep 06, 2022 06:48 AM
Please can someone help with a row level security query.I have the following tables
Entity A
User
Entity B
Name
Icon
A
Z
B
Z
C
X
D
X
F
C
ZA
C
I need to create a DAX formula to allow row level security on Entity B for the following logic
If a user is not in Entity A table then the user should be restricted to see only records where Icon <> C. If the user is in Entity A then they will have access to all records in Entity B
Any help much appreciated
Ben Hopes
FY3 9HR
——————————2. RE: DAX Formula to restrict data
Kaz Shakir
Posted Sep 09, 2022 07:08 PM
Edited by Kaz Shakir Sep 09, 2022 07:09 PM | view attached
@Ben Hopes,
I think this is relatively straight forward. I would create three measures:1. First, a measure to determine the current user:
CurrentUser = USERNAME()ā
āNote: there is also another function called USERPRINCIPALNAME() – you should try both to see which one gives you the result you need.2. Next, I would create a measure to determine if the current user is in Entity A:
CurrentUserInEntityA =
VAR _entityAMatchedRows =
FILTER(
ALL(‘Entity A’),
‘Entity A'[User] = [CurrentUser]
RETURN
COUNTROWS(_entityAMatchedRows) > 0ā
3. And third, I would create a measure to determine whether to show a given row in the current filter context:DisplayRow =
VAR _currentIcon =
MIN(‘Entity B'[Icon])
RETURN
IF(
AND(
NOT([CurrentUserInEntityA]),
_currentIcon <> “C”
“Display”,
“Don’t Display”
And then you can create a simple table visual to show Entity B, and use the [DisplayRow] measure as a filter on that visual:——————————
Kaz Shakir
TN
——————————Attachment(s)
pbixHopesExample_v1.pbix
The discussion ‘DAX Formula to restrict data’ is closed to new replies.
