DAX Formula Help
  • DAX Formula Help
    Posted by DSC Communities on May 5, 2022 at 1:58 pm
    • Beau A
      May 5, 2022 at 1:58 PM
      I need help with the below measure that will be used on a column graph with Month-Year as the XAxis (Ex. Jan-2021,Feb,2021,March,2021)
      1) var Maxdate1 is trying to determine the max date from my date table of any given period (Month for my visual – and my visual will only ever be at the month)
      2) HistoricalCount is trying to determine the total count all time
      3) Return is trying to display the count of all the historical data (even outside the chart month) that meets the following criteria.
      For some reason I am doing something wrong.. can anyone help?
      Measure 12 =
      var Maxdate1 = max(dim_date[DateKey])
      var HistoricalCountĀ = CALCULATE(count(table[subscription_id]),
      filter(table,table[status] in {“Active”,“Paused”,“Closed”}),all(dim_date))
      return calculate(HistoricalCount,filter(table,table[date_key] <= Maxdate1),
      filter(table,table[cancel_date] >= Maxdate1) || table[cancel_date] = Blank()))
      Beau A
      Analyst
      MI
    • Jean-Luc DJEKE
      May 9, 2022 at 6:49 AM
      Hello ,
      Can you post your .pbix in order to see how isĀ  done your tabular model please ??
      Jean-Luc DJEKE
      IngƩnieur BI
    • Vilmar Santos
      May 14, 2022 at 3:16 PM
      Tente esta abaixo. Se não der certo, envia seu pbi por favor
      Medida =
      VAR Var1 =
          MAX ( dim_date[DateKey] )
      VAR Var2 =
          CALCULATE (
              COUNT ( table[subscription_id] ),
              FILTER (
                  table,
                  table[date_key] <= Var1 &&
                  table[cancel_date] >= Var1 &&
                  table[status] IN { "Active", "Paused", "Closed" } ||
                  table[cancel_date] = BLANK ()
              ALL ( dim_date )
      RETURN
          Var2
      Vilmar Santos
    DSC Communities replied 3 years, 11 months ago 1 Member · 0 Replies
The discussion ‘DAX Formula Help’ is closed to new replies.
