DAX for Unichar Symbols and figures – % Chg
Posted by DSC Communities on May 20, 2020 at 6:15 pm-
William Skelley
MemberMay 20, 2020 at 6:15 PM
Hello:I am looking for assitance in writing the proper DAX to show both the percent change and then a down or up arrow based on it’s a positive or negative result.
When I just use one half of the measure it works, but not for me when I try to cover both bases.
This is what I have, that isn’t working.
% VAR to LY Sales =
SWITCH ([% VAR-LY],[% VAR-LY]<0, “?”, “”) & ” ” & FORMAT([% VAR-LY], “Percent”)[% VAR-LY]<0, “?”, “”) & ” ” & FORMAT([% VAR-LY], “Percent”),, BLANK())I am fine with getting jsut symbols but I’d like both symbols and numbers of the percent change(in this case).
This, below, works fine for symbols. I read it in a blog.
Variance just Symbols to Sales LY =VAR Down = UNICHAR(11167)VAR Up = UNICHAR(11165)VAR UpLots = UP & UpVAR Side = UNICHAR(11166)ReturnSWITCH(True(),[% VAR-LY] < 0, Down,[% VAR-LY] > 0.15, Up Plenty,[% VAR-LY] > 0.01,Up,Side)I have bolded the measure I could use help on.
Thank you,
Bill S.
William Skelley
01106
Longmeadow MA
8602807221
Vishesh Jain
MemberMay 21, 2020 at 2:29 AM
Hi ,Please can you try replacing the actual symbol in your measure with the UNICHAR code.
The symbol should work since it is text, but ideally I’ve seen UNICHAR codes being used in DAX.
Even the sample code that you shared, contains UNICHAR characters, defined in variables.
You can probably implement a similar approach.Hope this helps.
Thank you,
Vishesh Jain
Owner
VR Construction
William Skelley
MemberMay 21, 2020 at 7:51 AM
Hi Vishesh:Thank you for replying and giving me this suggestion! I remember you helped me out early on with a balance of year measure too.
Have a great day and it’s great you help so many!
Best regards,
Bill
William Skelley
01106
Longmeadow MA
8602807221
Vishesh Jain
MemberMay 22, 2020 at 3:45 AM
Hi William,Glad to be of assistance.
I had been out of office due to the pandemic for nearly 2 months and its good to be finally be back!
Hope you solve your issue.
Thank you,
Vishesh Jain
Owner
VR Construction
Krishna Nandan
MemberMay 21, 2020 at 12:59 PM
You can use KPI ticker. Search on get more visualization. Its very easy to use. https://appsource.microsoft.com/en-us/product/power-bi-visuals/WA104380946——————————
Krishna Nandan
SME
Bangalore
William Skelley
MemberMay 21, 2020 at 3:11 PM
Hi Krishna:Thank you for replying too! I just downloaded the KPI ticker visual and will check it out. I really appreciate that. Best regards,
Bill
William Skelley
01106
Longmeadow MA
8602807221
John Thomas
MemberMay 21, 2020 at 2:27 PM
Hi Bill!Check this out:
They even have a sample file…
Cheers!
John Thomas
Huntersville NC
William Skelley
MemberMay 21, 2020 at 3:09 PM
Hi John:Thanks very much for sharing that. I just watched it. So it makes sense. I did not not see the example file though. Maybe I’m missing where the link is.
Great stuff!
Thanks again.
Bill
William Skelley
01106
Longmeadow MA
8602807221
DSC Communities replied 5 years, 4 months ago 1 Member · 0 Replies -
The discussion ‘DAX for Unichar Symbols and figures – % Chg’ is closed to new replies.
