DAX – Actual vs Budget variance, how to calculate when applying filter on same column
Posted by DSC Communities on January 12, 2020 at 4:29 pm-
Stephane Gelinas
MemberJanuary 12, 2020 at 4:29 PM
Hello all,
I am a DAX beginner and need help your help!Ā Ā I am currently developing something in Excel (PowerPivot) and myĀ DAX formula that calculates a variance between budget and actual doesn’t work correctly when there is no value for an account, either at the “budget” or the “actuals”.
I have a data table that contains the budget and expenses for condominium units.
It is possible that for an account there is a value budgeted but we have no actuals (no line, e.g. a null value), and it is possible that there is an actual expense, but nothing was budgeted (again, no line).
The data table (which I simplified for this example) looks like this :
Year
Scenario
Account No
Account Description
Condo Unit
Amount
(Montant)
2019
Actual
5100
Electricity
6835
100
2019
Budget
5100
Electricity
6835
110
2019
Actual
5200
Maintenance
6835
50
2019
Budget
5300
Various expenses
6835
25
I would like to calculate a variance, based on applied filter (e.g., slice the report per Condo Unit).
The formula works when there is data in both actual and budgetĀ (e.g., the first two lines in the example), but doesn’t work,Ā or actually works occasionally, when either the actual or the budget has no value (example: the last 2 lines).
This is the formula I used (it’s in French so slightly different from the simplified example) :
Ecart:=CALCULATE(SUMX(DataTable, DataTable [Montant]), DataTable [ScĆ©nario]=”Budget”)-CALCULATE(SUMX(DataTable, DataTable [Montant]), DataTable [ScĆ©nario]=”RĆ©el”)
Example of the report :
Budget
RƩel
No Compte
CatƩgorie
Sous-catƩgorie
Montant
Montant
Ecart
1000
Cotisation régulière
9,974
30,843
-20,869
30,843
-20,869
5100
Assurances
Assurances
12,035
13,633
-1,598
5210
Entretien du bâtiment
Ventilation
4,397
-4,397
5225
Portes/fenĆŖtres et serrures
1,209
-1,209
5240
Luminaires
25
-25
5260
Articles saisonniers
126
-126
5280
Divers
2,000
5310
DƩneigement
Stationnements
794
830
-36
5320
DƩneigement
EntrƩes avant
641
670
-29
5330
DƩneigement
Escaliers
1,321
1,381
-60
5340
DƩneigement
Cours commune
263
275
-12
5350
DƩneigement
DƩglaƧage / Sel
18
-18
5410
Paysagement
Entretien
2,200
5420
Paysagement
RƩparations / remplacement
200
5500
ĆlectricitĆ©
ĆlectricitĆ©
1,300
1,358
-58
5610
Honoraires professionnels
Juridiques
379
-379
5700
Interphone
Interphone
600
626
-26
5710
Frais bancaires
Frais bancaires
360
319
41
5720
Frais de rĆ©unions et d’assemblĆ©es
Location de salle
300
264
36
5730
DƩpenses diverses
DƩpenses diverses
500
1
499
5910
Contingence
Contingence
1,500
5925
Transfert entre fonds
-14,041
20,682
-34,723
46,196
-36,223
Ā Any idea on how to fix this?Ā Ā Ā I tried splitting the query to have one table for the Budget and an other for the Actuals and linking both to a “calendar” table, but ended up having the same number repeating across linesā¦
Ā Any help would be greatly appreciated!
Ā Thanks!
Aubrey McKillop
MemberJanuary 12, 2020 at 5:21 PM
Stephane,ĀYou could wrap your formula with an IF State checking to make sure that budget and Actuals both have values.Ā If they do use the calculate if they do not apply another value such as 0
Aubrey
Aubrey McKillop
Director of IT
Moncton NB
Stephane Gelinas
MemberJanuary 12, 2020 at 5:51 PM
Hello Aubrey,ĀThanks for your reply.Ā Unfortunately it seems to yield the same results…Ā Ā
This is what I have tried :Ā
Ecart:=if(isblank(CALCULATE(SUMX(DataTable,DataTable[Montant]),DataTable[ScĆ©nario]=”Budget”)),0,CALCULATE(SUMX(DataTable,DataTable[Montant]),DataTable[ScĆ©nario]=”Budget”))-if(isblank(CALCULATE(SUMX(DataTable,DataTable[Montant]),DataTable[ScĆ©nario]=”RĆ©el”)),0,CALCULATE(SUMX(DataTable,DataTable[Montant]),DataTable[ScĆ©nario]=”RĆ©el”))
Best regards,Ā
Stephane
Paul Cooper
MemberJanuary 13, 2020 at 1:58 AM
The key is in the problem with many to many relationships.
The budget table cannot have a relationship with the actuals table as the account key will have many in both tables. That is no one-to-many relationship.
I solved this by creating a table with just the account numbers.Ā You may have that already, if so, that step is done.
Then use TREATAS to get the Budget Table to TREAT this account number (in the budget table) AS the Account Number in the Accounts table.
Alternatively use the TREATAS with SUMMARIZE to achieve this.
Excel will not recognise the TREATAS in intellisense as you type the formula but it actually does work.For detail see Matt Allington’s post here.
Virtual Filters Using TREATASExceleratorbi remove preview Virtual Filters Using TREATAS I have been aware of the TREATAS function for a very long time. I have tried to understand how it works a few times but could never really work it out. I think part of the problem is the function name TREATAS is not very descriptive. View this on Exceleratorbi > ——————————
Paul Cooper
Director
Rinstrum Pty Ltd
Acacia RIdge
0418744345
Stephane Gelinas
MemberJanuary 13, 2020 at 8:10 PM
Hello,Thank you for the reply,Ā this seems promising, I will explore the option.
Perhaps another way of solving this would be to add a bridge table, I just looked it up, it seems to be another way to fix the problems that can occur with many to many relationships.Ā Perhaps I could split my information in two tables (one for budget, the other one for actuals), and use the accounts table as a bridge table… I’ll look into this as well.
UPDATE
I split the information in two tables and used the account table as a bridge between the actuals and the budget table.Ā It seems to work correctly!
My DAX formula now looks something like thisĀ (translated as the formula uses some french terms) :
=SUMX(‘Budget’,Budget[Budget])-SUMX(‘Actuals’,’Actuals'[Actuals])
DSC Communities replied 5 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘DAX – Actual vs Budget variance, how to calculate when applying filter on same column’ is closed to new replies.
