Cummulative of Calculated Countrows by Month
  • Cummulative of Calculated Countrows by Month
    Posted by DSC Communities on February 15, 2018 at 1:30 pm
    • Alejandra Avila
      February 15, 2018 at 1:30 PM
      Hello!Ā
      Hope someone can help me with this I have been trying to create a measure that adds the monthly result of another calculated measure which uses COUNTROWS but I’m not being able to get the desired result, my measures are defined as follows:
      ReachedĀ Customers = COUNTROWS(FILTER(VALUES(‘Monthly'[Customers]),AND(‘Monthly'[PY Salesl]>1,[TY Sales]>1)))
      Cumm Reached Customers =
      VAR EarliestDate = CALCULATE(MIN(Calendar[Month]),ALLSELECTED())
      RETURN CALCULATE([Reached Customers],FILTER(ALL(CCalendar[Month]),Calendar[Month]<= MAX(Calendar[Month]) &&Ā Calendar[Month]>= EarliestDate))
      With this I get the following result:
      Month Reached Customers Cumm Reached Customers DESIRED Result
      01-Jan-17 22 22 22
      01-Feb-17 23 34 56
      01-Mar-17 32 47 103
      01-Apr-17 27 51 154
      01-May-17 32 55 209
      01-Jun-17 30 59 268
      As you see the Cumm Reached measure is only adding the different customers from each month, however what I need is for it to add month by month result (as shown in column DESIRED Result), I understand this is not working because my original measure “New Customers” is using COUNTROWS and VALUES thus filtering only distinct values, which is actually what I need for that measure, the problem comes when trying to add those values.Ā
      Please help!Ā
      AleĀ
      Alejandra Avila
      Store Intelligence
      MƩxico
      5533310967
    • Hasham Niaz
      February 15, 2018 at 2:50 PM
      Please try to correct your DAX using below articles;
      https://community.powerbi.com/t5/Quick-Measures-Gallery/Running-total/td-p/218593
      https://www.mssqltips.com/sqlservertip/4841/calculating-mtd-qtd-ytd-running-and-cumulative-total-in-power-bi/
      You can easily find DAX solution to Running Total problem
      Hasham Niaz
      Sr. BI Consultant
      Karachi, Pakistan
    • Kevin Zandee
      February 16, 2018 at 5:39 AM
      It appears you are trying to use month instead of date try something like below
      CALCULATE([Reached Customer],FILTER(ALLSELECTED(Cal), Cal[Date]<= MAX(Cal[Date])))
      Kevin Zandee
      Consultant
      GT Services
      Calgary AB
      4038806941
    DSC Communities replied 7 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Cummulative of Calculated Countrows by Month’ is closed to new replies.
