Conditional Formatting on a measure
  • Conditional Formatting on a measure
    Posted by sam-duval on March 9, 2020 at 11:12 am
    • Sam Duval
      March 9, 2020 at 11:12 AM
      I have a measure that i created that returns a percentage, I apply a conditional formatting on it to put a “flag” on the record if its greater than 50%. It works fine when applied as a whole, but if I filter the table at all. The record gets flagged as “True” under the conditional formatting rule, even though the calculated value is well under the 50% threshold.Ā
      any ideas how to remedy?
      Sam Duval
      Data Quality Analyst
      Indianapolis
    • colin mcilwain
      March 9, 2020 at 11:26 AM
      Are you using ‘percent’ in the conditional formatting rather than ‘number’? If so, try changing it to ‘number’ with a value of 0.5.
      See this post ?
      Colin.
      colin mcilwain
      Lead Process Specialist
    • Sam Duval
      March 9, 2020 at 11:30 AM
      Thanks not sure why that would make a difference, but it did the trick. Table formats correctly now.
      thanks.?
      Sam Duval
      Indianapolis
    sam-duval replied 5 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Conditional Formatting on a measure’ is closed to new replies.
