Combobox Default Selected Items will only work for 1 Item
  • Combobox Default Selected Items will only work for 1 Item
    Posted by DSC Communities on April 14, 2020 at 6:29 pm
    • Justin Hosch
      April 14, 2020 at 6:29 PM
      ?I have a ComboBox filled with multiple users filtered from Office365Users.SearchUser.Ā  I also have a collection of users I’ve stored in a variable that I want to use as my DefaultSelectedItems.Ā  For some reason the default only works if I select the first record from the collection using the First function or I don’t select the multi-select option in the ComboBox.Ā  Can anybody help me figure out what is going on with this?
      It looks like RenameColumns is causing my issue.Ā  If I just create a table with a couple of rows it works fine.
      This is how I’m setting the VarSelectedUsers.
      ClearCollect(VarSelectedUsers,RenameColumns(Split(Gallery1.Selected.Owner,”;”),”Result”,”DisplayName”));
      Justin Hosch
    • Justin Hosch
      April 16, 2020 at 11:36 AM
      The Split function was creating an empty row because the string ends in a semi-colon which ended up causing my issues.Ā  If I filter out the blank row it works.?
      Justin Hosch
The discussion ‘Combobox Default Selected Items will only work for 1 Item’ is closed to new replies.
