Check If Column value of one table matches with column value of another table then perform operation
  • Check If Column value of one table matches with column value of another table then perform operation
    Posted by DSC Communities on August 23, 2022 at 5:16 pm
    Check If Column value of one table matches with column value of another table then perform operationFollow
    Prince Kumar
    Prince KumarAug 23, 2022 02:32 AM
    Hi Guys, I have a table that is having some divisions values named tableA(this is used in matrix) …
    1. Check If Column value of one table matches with column value of another table then perform operation
    Prince Kumar
    Posted Aug 23, 2022 02:32 AM
    Hi Guys,
    Bakery
    Camera
    Food
    Household
    Chairs
    Fans
    I have target table ,that is having targets based on each division for this year
    Division Target_0 Target_50 Target_100 Target_150 Year
    Bakery 0.36 0.38 0.41 0.46 2022
    Camera 0.52 0.54 0.56 0.61 2022
    Food 0.48 0.5 0.52 0.57 2022
    Household 0.36 0.39 0.42 0.48 2022
    I have measure that is having these values and i need to check if divisions(table A) is present in division of target table then match it’s corresponding rows to measure
    if the measure is less target_50 column then true else false.
    I created measure but this works only for one row, i was trying to compare tableA[Division] with ‘Target table'[Division] directly through related also ,it isn’t working
    VAR CHECK_RED=IF (FIRSTNONBLANK((tableA[Division]), 1) =FIRSTNONBLANK((‘Target table'[Division]), 1) &&
    FIRSTNONBLANK((‘Yearly Targets'[Year]), 1)=”2022″,
    IF(FORMAT(‘View By'[Measure],”Percent”)<FORMAT(FIRSTNONBLANK((‘Target table'[Target_50_Percent]),1),”Percent”),True,False),False)
    RETURN
    CHECK_RED
    Could u please guide me how we can compare 2 columns here? Just need comparison for 2 columns
    Prince Kumar
    Consultant- Cloud Data Engineer
    2. RE: Check If Column value of one table matches with column value of another table then perform operation
    Kaz Shakir
    Posted Aug 29, 2022 08:06 PM | view attached
    @Prince Kumar,
    It would be easier to answer your question if you post a .pbix file with a sample of your data and your data model.
    Based on what you described, I tried to create what I think your data and model look like.​ I think you have three tables like so:
    Division:
    Target:
    Results:
    And the data model might look like this:
    In that case, you could add two calculated columns to the Divisions table, that would have formulas like this:
    Does Division Have Target_50 =
    NOT(ISBLANK(RELATED(target[Target_50])))
    Are results for division less than Target_50 =
    IF(
    divisions[Does Division Have Target_50],
    IF(RELATED(results[Value]) < RELATED(target[Target_50]), “True”, “False”),
    BLANK()
    And then you can create a table visual to show the results:
    Hope that helps. Please consider posting your ,pbix file, and we will be able to give you a more customized answer.
    Kaz.
    Kaz Shakir
    TN
    Attachment(s)
    pbixprincekumar_example_1.pbix
    replied 2 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Check If Column value of one table matches with column value of another table then perform operation’ is closed to new replies.
