Calculate Cumulative% in decreasing Order and filter it by Cumulative% Slicer
  • Calculate Cumulative% in decreasing Order and filter it by Cumulative% Slicer
    Posted by DSC Communities on April 17, 2020 at 3:39 pm
    • saurabh Singh
      April 17, 2020 at 3:39 PM
      Hello,Ā Ā
      I’m having a table of material code (type Text) & its value (type decimal). I need to create a table of all materials having Value (in decreasing order) and its cumulative %.Ā
      Later i want this slicer of cumulative % to filter the data. For example – List of materials having top 68% of stock
      Thanks and Regards:-
      Saurabh Singh
    • Vincent Lacomme
      April 19, 2020 at 5:33 AM
      Hi Saurabh,
      Creating the cumulative % can be accomplished using a measure.
      However, you can’t use a measure as a filter for a matrix.
      So I created a second table that summarize your data (with distinct material ID) and with a cumulative % column. Then I use this second table as a filter.
      Enclosed is an example PBIX.
      Vincent L.
      Chartered accountant – Expert-comptable
    • saurabh Singh
      April 19, 2020 at 8:14 AM
      DearĀ Vincent L.,
      Very thanks for your solution.Ā
      The provided solution guided me towards a right path but their small issue with cumulative % calculation.
      Cumulative % should be increasing till it’s 100% in last row of table (if no filter is applied) like running total.
      Request you to please have a look on cumulative % calculation.
      Saurabh singh
      saurabh Singh
      Manager
The discussion ‘Calculate Cumulative% in decreasing Order and filter it by Cumulative% Slicer’ is closed to new replies.
