Breakdown of advancement in percent.
  • Breakdown of advancement in percent.
    Posted by DSC Communities on June 28, 2020 at 5:38 am
    • GĆ©rard Ducouret
      June 28, 2020 at 5:38 AM
      I have a long list of projects with their progress in %. I want the number of projects between 0 and 50% of progress, and the number of projects between 50% and 100%. How can I do this with Power BI Desktop?
      Thanks for your help
      GƩrard Ducouret
    • Kenneth Tyler
      June 29, 2020 at 10:54 AM
      Gerard,
      It sounds like you have a case of “segmentation”Ā https://www.daxpatterns.com/dynamic-segmentation/
      Basically you write a measure that will give you flag values for each project (below 50/above 50) and then you can write another measure that uses that result to do a count of the two segments.
      Kenneth Tyler
      94710
      Berkeley CA
      5103847321
    • GĆ©rard Ducouret
      June 29, 2020 at 12:11 PM
      Kenneth,
      Thanks a lot!
      I’ll work on that
      GƩrard Ducouret
    DSC Communities replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Breakdown of advancement in percent.’ is closed to new replies.
