Bookmark Issue – Slicer holding selection Incorrectly
  • Bookmark Issue – Slicer holding selection Incorrectly
    Posted by DSC Communities on October 19, 2022 at 11:38 am
    • Beau A
      October 19, 2022 at 11:38 AM
      *issue in red below
      I have dashboard made up of 1 page/tab.Ā
      On this page I switch between visuals using two bookmarks linked to 2 buttons.Ā
      bookmark 1
      Site – currently holds selection when switching from (bookmark 1 -> 2) which is good and what I want
      State – currently holds selection when switching from (bookmark 1 -> 2) which is good and what I want
      Cohort – currently holds selection when switching from (bookmark 1 -> 2) which is good and what I want
      bookmark 2
      Date – as soon as I change the date range my page adjusts which is correct, but then I switch back to (bookmark 1) and the date slicer.. which isn’t a part of bookmark 1 (as in it’s de-selected from this view) is somehow filtering the Bookmark 1 view. Can someone tell me how to keep the selection from (site,state,cohort) but not have the selection from date keep.
      Beau A
      Analyst
      MI
    • Sara Leasy
      October 20, 2022 at 7:24 AM
      Do you have the option “Keep all filters” turned on?
      Just wanted to ask, just in case someone else has the same question.
    • Travis B
      October 20, 2022 at 8:42 AM
      I just went through this same kind of scenario.Ā  I had a page with three bookmarks – each one would switch the information being presented in my visuals (in my case, a couple of tables and a KPI card) and it all worked fine except when I would change the date range (a slicer with the month).Ā  The current bookmark view that I was on would update as necessary, but go to a new bookmark, and the date range reverted to the original month.Ā  What I ended up doing is duplicating the visuals on my page and applying any filters at the visual level, instead of page level. Then using a combination of hiding visuals, and then configuring the bookmark options Data unchecked and Selected Visuals checked, I selected the relevant visuals on the page and updated each bookmark.Ā  This now allows me to view each bookmarked view and the Month date range slicer doesn’t get saved with the bookmark.Ā
      Hope this helps a bit.
      Travis Bird
The discussion ‘Bookmark Issue – Slicer holding selection Incorrectly’ is closed to new replies.
