Bookmark don’t work in PowerBI Service
Posted by DSC Communities on February 19, 2020 at 4:45 am-
Rini van Rijswijk
MemberFebruary 19, 2020 at 4:45 AM
?I’m not a specialist in PowerBI desktop and PowerBI service. I have a issue concerning the working of bookmarks in the PowerBI service. A solution made in PowerBI desktop is working well. After publishing to a workspace on the PowerBI service one of the bookmarks is not working. There is a switch in the solution. When the switch is off the visual of a column chart is displayed well. When the switch is turnedĀ onĀ the solution should display a table visual. That doesn’t happen. Only a empty visual is being showed. Even the title of visual isn’t showed. The powerBI desktop is showing it well.
I have checked all bookmarksĀ with correspondingĀ selection’s parameters are the same on the powerbi service and the powerbi desktop solution.There are no differences between them.I begin to suspect there is a PowerBI service bug. Is there someone who has the same problem? Is there someone who knows wahts happening and know how to solve this issue?
greetings
Rini van Rijswijk?
Jonathan CHANAL
MemberFebruary 19, 2020 at 2:58 PM
Hello,I use a lot of bookmark without any issue like this. Try to get the same result in your Power BI Desktop. If there is no problem, delete your dataset in the service and publish again your report. Sometimes, I have a problem with the theme of my report when I upload the first time my report into the Power BI Online Service (The theme is not the right theme for example). Then I do that, delete, and re-publish and it works fine…
Before doing that, check again your selection pane, you may have a blank, hidden visual and this is just the problem, do an update of your bookmark.
Bye,
Jonathan CHANAL
Chef de Projet Digital / Data Analyst
Grenoble
Rini van Rijswijk
MemberFebruary 20, 2020 at 9:48 AM
?Hello Jonathan,Thank you for your suggestions. I have done everything you suggested.. It gives no results in solving the problem. I have investigated the problem futher. I know for sure the problem is not related to the bookmarks. In another tab with no bookmarksĀ i placed a simple table and published it to PowerBI service. Also there de table visual was not visible. When i changed the visual to Multi card it comes up is displayed well in PowerBI service. When i want to change it to table visual back again nothing happensĀ The visual ttype stays Multi card. It looks like it is typical related to visual type table.
I hope you another suggestion for me.
greetings
Rini van Rijswijk——————————
Rini van Rijswijk
Data Analyst
Gemeente Alphen aan den Rijn
Jonathan CHANAL
MemberFebruary 20, 2020 at 12:14 PM
I’m sorry for you, I don’t have any idea š——————————
Jonathan CHANAL
Grenoble
Rini van Rijswijk
MemberFebruary 26, 2020 at 4:41 AM
?Dear Jonathan,The problem is solved. The issue was publishing solution with the december 2019 version. With the february version the problem was solved.
Thank you for advise.
Rini van Rijswijk
Data Analyst——————————
Jonathan CHANAL
MemberFebruary 26, 2020 at 5:59 AM
Hello,Ok perfect.
Have a nice day,
Jonathan CHANAL
Grenoble
DSC Communities replied 6 years, 1 month ago 1 Member · 0 Replies -
The discussion ‘Bookmark don’t work in PowerBI Service’ is closed to new replies.
