I have an app that has a list of items being pulled from a SQL Table.Ā I added a new screen with the scanner button and I am looking to see if it is possible to scan the UPC (ItemNumber) and directly go to the edit screen based on the item number scanned.
I have been able to navigate to the screen without issue on the scan but it does not load the proper item.
Thank you for any help.
Aubrey
—————————— Aubrey McKillop Moncton NB ——————————
Warren Belz
May 11, 2020 at 1:34 AM
HI Aubrey, What code are you using on the OnScan of the barcode scanner? Assuming ItemNumber is a unique identifier in your list and your scanner was named BarcodeScanner1, you would do something like this OnScan.
