Barcode Scanner Help
  • Barcode Scanner Help
    Posted by DSC Communities on April 16, 2020 at 5:37 pm
    • Timothy Gibble
      April 16, 2020 at 5:37 PM
      Hello UG,
      I am developing an app using the barcode scanner control.Ā  I have a local collection, called ListAll, where the title column are part numbers and another column with the part description.Ā  I have the app setup where the user scans a barcode that returns a part number.Ā  I then have a label that looks up the part number in the collection and returns the description (LookUp(ListAll, Title = Label11.Text).Description).Ā  The issue is, when I use the barcode scanner, the part number appears but the description does not.Ā  If I change the label to show the text and not the barcode result (“73520-986”), the description appears.Ā
      My question is, why is the barcode scanner result not the same as a manual text.Ā
      Please see the screen shot below.Ā  The number next to the “Scan” button is a result from the barcode scanner.Ā  The number circled in red is just a label (“73520-986”).Ā  The yellow circle is a function where it returns true of the label in red matches the barcode scan result, and false if they are not equal. The numbers appear to be the same.Ā Ā
      Thanks for you help.Ā Ā
      Tim
    • Andy Tippin
      April 16, 2020 at 6:57 PM
      I played with Barcode scanner previously but my lookup was done on an integer from SQL. I remember that I had to use .Value to keep it as a number. Otherwise it treated it like text by default.
      You can try to substitute Lookup with Filter or Search maybe?Ā https://docs.microsoft.com/en-us/powerapps/maker/canvas-apps/functions/function-filter-lookup
      Andy Tippin
The discussion ‘Barcode Scanner Help’ is closed to new replies.
