Two companies with same Name in same GP instance
  • Two companies with same Name in same GP instance
    Posted by Rick Heinrichs on May 1, 2024 at 2:03 pm
    Hey Everyone,
    Just reaching out to see if anyone has had to setup a GP instance with 2 companies of the same name in GP? We have 2 companies in different countries with the same legal entity names that want to be a part of the same GP. Obviously GP states that you cant when you try to change names to the same as the other but we do orders, invoices, cheques/checks, payroll, etc from them. Any suggestions out there how to best handle this? Thanks
    R
    Rick Heinrichs replied 1 year, 10 months ago 4 Members · 8 Replies
  • 8 Replies
    May 1, 2024 at 2:35 pm
    Hi Rick,
    The databases can’t have the same name, but I’ve never seen it not take similar and exact names in the description of the database in the SY01500. However, if you are getting an error, try just adding a period (.) to the end of one of the names and let us know what happens
    • Rick Heinrichs
      May 1, 2024 at 3:38 pm
      Thanks Jo but this would just ask for a world of hurt for those with access to both. It would also not look clean with our cheques/checks and invoices and payroll all having a . on the end of the company name on one of them.
      Was wondering if anyone has appended a country code on the end or such if that still goes through like tagging one with USA on the end?
      R
  • Chris Giesbrecht
    May 1, 2024 at 3:05 pm
    I echo what Jo has said. Database names have to be different.
    Also, the is a product by Binary Stream that allows you to run multiple legal entities inside 1 GP company, so you can share all your master record information (customers, items, vendors, etc) between the companies if that would make sense in your scenario. We use it and it works pretty slick for us!
    • Rick Heinrichs
      May 1, 2024 at 3:42 pm
      Hey Chris,
      Is this 1 actual GP company or still 2 and it syncs between them somehow? Not sure if this works cross borders and currencies?
      R
    May 3, 2024 at 7:42 am
    Rick,
    I would still advise to make the company names the same EXCEPT at the end of them you can add “US” and “CAN” or whatever countries they are in.
    Such as ‘Aisling Dynamics US” and “Aisling Dynamics UK”.
    That should distinguish for the end users AND you can use a different field to pull in any legal name you need on forms.
  • Kerry Hataley
    Organizer
    May 3, 2024 at 9:28 am
    Good Morning Rick,
    So there are a couple of concerns that you need to think about…
    1. Is there any report, check or such that will display the ‘Company’ name and is that going to be the CORRECT LEGAL name that can be used.
    For example I have my company registered in both US and Canada with the same name (Nanook Software, Inc) – I do not want US / CND for marketing reasons.
    How I get around it is with the <space> trick. Since Dexterity (Programming in Dynamics GP) has code to strip spaces at the beginning and end of the Company Name, you need to **HIDE** the <space> in the Name. I hope the name is NOT a single word.
    So for me I use:
    Nanook<space>Software,Inc for US
    Nanook<space>Software,<space>Inc for Canada
    You see the <space> added to the ‘ ,Inc ‘
    Now for single word company names, you have a problem – you must add a char somewhere.
    You can add an extended ascii char or even a non printing ascii char- with care.
    WARNING – DO NOT JUST change it in the SQL Table SY01500, it will create issues. I looked into the source code, you will have problems.
    For the users, not to get confused I would suggest using one of the many tools that changes the background colour for each company. (Winthroup – GP Power Tools and WilloWare – GP PowerPack have tools available)
    I hope this helps.
    • Rick Heinrichs
      May 3, 2024 at 10:46 am
      Down Accepted answer
      Yes Kerry! We do have GP Power Tools but didnt realize the space thing and put these 2 together. Definitely the piece I was hoping for. This should do. Thanks so much!
      R
