Targeted Rebuild of RM00401?
  • Targeted Rebuild of RM00401?
    Posted by David Morinello on January 25, 2023 at 9:48 am
    • David Morinello
      January 25, 2023 at 9:48 AM
      Does anyone have a SQL Script to manually do a limited repair/rebuild of the RM00401 ?
      In this case, one payment record is in RM20101 but is not present in RM00401.
      I just want to rebuild the one, not look through the 35 million.
      Why not do Check Links? 35 million rows in Receivables Open Transactions. (Don’t get me started on why…)
      Thoughts?
      David Morinello
      Senior Developer
      TruckPro LLC
      Cordova TN
    • Windi Epperson
      January 26, 2023 at 1:13 PM
      Hey
      I’ve never tried these options but I’m wondering if one of them might be just enough to add your missing record to the table.
      First thought – UtiliiesReconcile for just this customer.Ā  You might could add more restrictions if this customer has a ton of transactions.
      If that doesn’t work, I’m wondering if you could use PSTL to unapply the payment, then reconcile, then re-apply the payment.
      Nothing really says that either of these options will update the RM00401 table, but they might be small enough options you could try.
      Windi?
      Windi Epperson
      Customer Support Manager
      Njevity, Inc
      Norman OK
      720-870-9700 x104
    • Jim Harris
      January 27, 2023 at 9:55 AM
      I’ve always just added these manually to RM00401, but this should work.Ā  Just fill in your payment number and un-comment the second row.
      SELECT DOCNUMBR, RMDTYPAL, 2 AS DCSTATUS, BCHSOURC, TRXSORCE, CUSTNMBR, CHEKNMBR, DOCDATE, 0 AS NEGQTYSOPINV
      –INTO RM00401
      FROM RM20101
      WHERE (DOCNUMBR = ‘PYMNT7593302’)
      Jim Harris
      ExamWorks, Inc.
      Atlanta GA
    • David Morinello
      January 30, 2023 at 11:33 AM
      Thanks everyone!
      Had a few days when I couldn’t login to reply. All the responses were great!
      David Morinello
      Senior Developer
      TruckPro LLC
      Cordova TN
    David Morinello replied 3 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Targeted Rebuild of RM00401?’ is closed to new replies.
