Does anyone know if there is a smartview that I can use to see which vendor has this option enabled?Ā We uploaded new vendors using a smart connect map, and while every vendor has an e-mail address listed in their E-mail to: section, the option to Enable remittances was not clicked on…but we can’t seem to run a report to see which ones need to be enabled.
—————————— Peri Anderson MD Financial Management Ottawa ON ——————————
Aref Karam
May 14, 2020 at 1:25 PM
Hi Peri,
If you have access to SmartList Builder, follow these steps to create the SmartList/SmartView: * In the Vendor e-Mail Options window: * Click on Tools * Select Table Finder * Select Email Card Documents table * Select Create SmartList * The SmartList Builder will open up * Enter and ID and Name for the new smartlist * Select the checkboxes under Default * Change Series to Purchasing * Click Save
FYI, You might need to addĀ other tables to get more info in this smartlist but this should give you a good start.
—————————— Aref Karam Data Consultant LTI Information Technology Ann Arbor MI —————————— ——————————————-
