Smartlist Issue
  • Smartlist Issue
    Posted by DSC Communities on April 20, 2017 at 3:13 pm
    • Trish Robertson
      April 20, 2017 at 3:13 PM
      When exporting a Smartlist from Excel – the date columns are coming across with the formula as text. Ā See Column A, H & I
      I’ve checked Excel to make sure the display formulas is unchecked. Ā I’ve performed the export as SA and the user from 2 different machines and get the same result. Ā Any ideas on how to get it to export as a date?
      Trish Robertson
      Helpdesk Supervisor
      CFRLTD
      Greenville SC
    • Terry Horn
      April 20, 2017 at 5:27 PM
      Hi Trish,
      You have probably already checked this, but is the field defined as a date in SmartList Builder.
      The other item I would check is whether or not if you have
      SmartListEnhancedExcelExport=True
      I found this string also if it helps any https://community.dynamics.com/gp/f/32/t/119753
      Terry
      ——Original Message——
      Trish Robertson
      Helpdesk Supervisor
      CFRLTD
      Greenville SC
    • Trish Robertson
      April 20, 2017 at 5:29 PM
      SmartListEnhancedExcelExport=True Ā – this worked! Ā Thanks
      Trish Robertson
      Helpdesk Supervisor
      CFRLTD
      Greenville SC
    DSC Communities replied 8 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Smartlist Issue’ is closed to new replies.
