SmartConnect “There was an error reading from the pipe: The pipe has been ended
  • SmartConnect “There was an error reading from the pipe: The pipe has been ended
    Posted by DSC Communities on August 3, 2017 at 3:37 pm
    • Steve Burney
      August 3, 2017 at 3:37 PM
      ??Hello everyone,
      We have a SmartConnect map that will run for approximately 10 minutes and then gives us the message “There was an error reading from the pipe: The pipe has been ended”.
      This causes the process to be halted.
      We have researched this and we are trying to get a grab on what causes this certain error.
      Any assistance will be appreciated.
      Steve
      Steve Burney
      GP Administrator
      Nissan Trading Corporation Americas
      Franklin, TN United States
      s_burney@nitco-us.com
      615-821-6792
      Twitter @SteveBurney
    • Vinod Agrawal
      August 4, 2017 at 12:54 AM
      Steve,
      The eConnect for Microsoft Dynamics GP Integration Service is a WCF service.Ā AĀ connection can remain inactive, during which no application messages are received, before it is dropped after 10 minutes. This is by default.
      RESOLUTION
      AddĀ receiveTimeout=”infinite”Ā to the Microsoft.Dynamics.GP.eConnect.Service.exe.config file for the eConnect Integration service. The binding section shouldĀ resemble this:
      <binding name=”eConnectNamedPipeConfig” closeTimeout=”00:10:00″ sendTimeout=”00:10:00″ receiveTimeout =”infinite” transferMode=”Buffered” hostNameComparisonMode=”StrongWildcard”Ā maxBufferPoolSize=”2147483647″ maxBufferSize=”2147483647″ maxReceivedMessageSize=”2147483647″><readerQuotas maxDepth=”60″ maxStringContentLength=”2147483647″maxArrayLength=”2147483647″ maxBytesPerRead=”2147483647″ maxNameTableCharCount=”2147483647″ /><security mode=”Transport”><transport protectionLevel=”EncryptAndSign” /></security>
      </binding>
      Vinod Agrawal
      Flovian it Services (P) Ltd.
      http://www.flovianit.com
      +1 (315) 636-4543
    • Steve Burney
      August 4, 2017 at 10:57 AM
      ?Thanks Vinod.
      We realized that this is what we had in there previously.
      When we made the previous changes then here is the error we receive now.
      “The transaction associated with the current connection has completed but has not been disposed. The transaction must be disposed before the connection can be used to execute SQL statements.”
      Any advice will be appreciated.
      Steve
      Steve Burney
      GP Administrator
      615-821-6792
    • Blair Christensen
      August 7, 2017 at 9:49 AM
      ?At this point you need to find out why things are timing out.Ā  You can try to do it yourself by using SQL Profiler to find out the actual SQLĀ statements being sent to the engine – there could be a problem in the way the transactions are crafted or it could be just a matter of sheer volume.Ā  The other option is to contact Support and ask them for assistance.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Leh Fabros
      August 4, 2017 at 1:37 AM
      Hi Steve,
      Here is a link that helped me resolved the same issue I had with SmartConnect.
      Tech Tuesday: Importing Large Documents Using SmartConnect | eOne Solutions
      It will point you to the different eConnect configuration that could be the possible caused of your issue.
      I hope this helps.
      Kind regards,
      Leh Fabros
      DXC Eclipse
      New York NY
    • Steve Burney
      August 4, 2017 at 9:13 AM
      ?Thank you very much Leh.
      I will pass this along to our IT group for them to review this solution.
      Thanks again!!
      Steve
      Steve Burney
      GP Administrator
      615-821-6792
    DSC Communities replied 8 years, 3 months ago 1 Member · 0 Replies
The discussion ‘SmartConnect “There was an error reading from the pipe: The pipe has been ended’ is closed to new replies.
