Serial Numbers Sold
  • Serial Numbers Sold
    Posted by DSC Communities on April 24, 2017 at 11:19 am
    • Shelly Tagtmeyer
      April 24, 2017 at 11:19 AM
      Has anyone had to deal with this scenario? Ā If so, what actions do you take to return the serialized items to stock since they are already showing as sold?
      Sell s/n to customer xyz
      Order is cancelled after it ships so you recall package and want to put the items back into new stock but since the serial number shows as soldĀ it won’t allow you to sell it again.
      Thanks in advance
      Shelly
    • Matthew Arp
      April 24, 2017 at 11:24 AM
      If you just have the serial number marked as sold, that means it is simply just still fulfilled on an invoice, go into that invoice and unfulfill it or void it.
      If the serial number has been invoiced it would no longer be in GP and you’d need to issue a return to get the serial number back in.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Shelly Tagtmeyer
      April 25, 2017 at 8:01 AM
      Matthew
      Yes, sales order has been invoiced. Ā When we create a RMA and receive it in then try to sell it again on another sales order it doesn’t let us fulfill it because it says that serial number is already sold. Ā Is it possible we are not setting up the RMA correctly?
      Thanks!——————————————-
    • Matthew Arp
      April 25, 2017 at 9:11 AM
      Field Service is notorious for having issues with inventory. I would recommend running Inventory Reconcile against an item that has a serial being marked as sold. If that fixes the issue, I would check to make sure that your RMAs are being fully closed and that you aren’t seeing any error message on any postings.
      Matthew Arp
      Hunton Group
      Houston TX
    DSC Communities replied 8 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Serial Numbers Sold’ is closed to new replies.
