Refreshable Excel Reports
  • Refreshable Excel Reports
    Posted by DSC Communities on February 28, 2017 at 11:54 am
    • Jolaine Bowman
      February 28, 2017 at 11:54 AM
      I am not a technical person, how do I explain to our IT Department the access that is needed for individuals that I want to create reports for?
      Jolaine Bowman
      Treasury & AP Manager
      Medica
      Minneapolis MN
    • Kelly Hobart
      February 28, 2017 at 4:16 PM
      This may be a good place to start:
      https://community.dynamics.com/gp/b/dynamicsgp/archive/2012/11/02/excel-reports-security
      Kelly Hobart
      Business Data Analyst
      Mount Pleasant Waterworks
      Mount Pleasant SC
    • Jeff Pfershy
      March 1, 2017 at 9:26 AM
      Jolaine,
      It depends on which version of GP your running. The archive noted by Kelly was when SmartList Builder (and Excel Report Builder) were part of the Microsoft offering, but it has since returned to eOne.
      In newer GP versions (2015+ for sure, possibly 2013?) the security is a bit different, although the basics are still the same, which are two parts:
      1. If storing reports on a network share, a report user will need ‘full control’ access for their windows (AD) account to the folder where the report is stored;
      2. The windows (AD) account needs to be added as a login in SQL and be assigned to the appropriate database role for the company the report pulls data from. Database roles for Excel Reports are predefined for basic reporting roles, like ‘rpt_accounting manager’, ‘rpt_accounts payable coordinator’, etc.
      Also, If you create a custom report using a table, view, stored procedure, etc. the database security role doesn’t have access to, you will need to add those objects to the role’s permissions.
      Hope that helps!
      Jeff Pfershy
      Solution Consultant
      248-489-0707
      The TM Group, Inc.
      Farmington Hills MI
    • Blair Christensen
      March 1, 2017 at 10:00 AM
      Here’s the simple way:  ask them to build you the views, create a security group with READ access to the views, and then add individuals to the security group.  That way you aren’t depending on Dynamics security but basic database security.  This allows any user in your company – even someone who doesn’t have a Dynamics user login – to access the reports.  It also makes it very easy for any kind of BI tool to attach to the views and begin serving up reports – whether that is Excel, Power BI, SSRS, or a host of other tools.
      If your database guys need some pointers on which tables contain what, I’d point them to Victoria Yudin’s very helpful site:  https://victoriayudin.com/gp-tables/
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
The discussion ‘Refreshable Excel Reports’ is closed to new replies.
