I have a number of open receipts that need to be switched to different PO’s. The receipts will not come up as an option to pick in the Purchase Return transaction entry window. I have checked that there is enough inventory available, I have reconciled the items and the receipts still don’t some up. The PO is not closed.
Why will the receipt not come up to be returned and backed out? Is there another way to do this? THANK YOU!
—————————— Teresa Waters Controller La Crosse Milling Company Cochrane WI ——————————
This only means the receipts are fully consumed based on your inventory valuation method – this happens often when receipts are of Shipment/Invoice type. The workarounds, should you want to avoid the headaches, are as follows:
1. Print the Purchase Receipts report (Inventory > Reports > Activity > Purchase Receipts) and see if you can spot other receipts you can pull from.
or,
2. You can do the return manually by posting two separate transactions, the first one is adjustment entry to correct the inventory balance, and the other transaction is an AP credit memo to correct the vendor balance (if needed).
—————————— Mariano Gomez Bent, MVP, Dynamics Credentialed Professional Director of Technology Mekorma ROSWELL GA —————————— ——————————————-
Kristy James
July 15, 2022 at 9:43 AM
Hello –
I came across this post as I’m having the same issue and have a follow up question. If I select the Returns Transaction Entry type of “Return”? I don’t have any receipts available. If I select “Return w/Credit” then I do have receipts (all the ones that I expected from the report you recommended). Does this make sense? We’re new to using the POP Returns in GP and it always seems like more of a hassle than it should be.
