Power BI Months in Chart
  • Power BI Months in Chart
    Posted by DSC Communities on December 19, 2016 at 3:26 pm
    • Matthew Devall
      December 19, 2016 at 3:26 PM
      All,
      I’m attempting to create a chart in Power BI.  When I create the axis with the months, the months go in alphabetical order instead of January thru December.  How do I make the chart show January then February and so on.
      I’m pulling data from an excel file.  Any help if appreciated.  This is my first attempt at Power BI.
      Matthew Devall
      Devall Towing & Boat Service of Hackberry, LLC
      Sulphur LA
    • Travis Smith
      December 20, 2016 at 3:11 AM
      Try changing your data to 01/01/2016.
      Travis Smith
      WithoutWire Inventory Sciences
      Minneapolis MN
    • Matthew Devall
      December 20, 2016 at 6:56 AM
      I did try that.  That goes in the order of January then October, November, December, then back to February. It goes 1/xx, 10/xx, 11/xx, 12/xx, 2/xx, 3/xx and so on.
      That’s why I switched to months.  I thought it would recognize months.
      I see there is a filter but I haven’t found a sort.
      Matthew Devall
      Sulphur LA
    • Mark Wiley
      December 20, 2016 at 8:25 AM
      I found this:
      Power BI Tips: Sort by Month Name
      Data Bear remove preview
      Welcome to our first of the Power BI Tips series.
      View this on Data Bear >
      Mark Wiley
      Senior Consultant
      Tribridge
      Stow OH
    • Matthew Devall
      December 20, 2016 at 12:26 PM
      Mark,
      I click your link and figured it out!  Thank you so much.
      Matthew Devall
      Sulphur LA
    • Aaron Back
      December 20, 2016 at 8:33 AM
      If the Month names are based on a date field, then create a Calculated Column and use the MONTH(<insert date field here>) formula. This will put the Month Number (1 for Jan, 2 for Feb, etc) in the column. Then use this for the Sort Column in your chart.
      Aaron Back
      Team Lead, IT | CareSource
      Email: Aaron.Back@caresource.com
      Chairman, GPUG Advisory Committee
      GPUG All-Star
      Summit Programming Committee
      Chapter Leader, Ohio
    • Anne Provost
      December 20, 2016 at 9:58 AM
      For your data set, you need to create a Month in Year and  Month in Year Sort column and then in Modeling, choose the Month in Year column and sort by the MonthInYearSort column.
      MonthInYearSort = MONTH(‘Calendar'[Date])
      Month in Year = FORMAT(‘Calendar'[Date], “MMM”)
      Works great if you have a calendar year end.
      Anne Provost
      Chief Financial Officer
      TNR Technical, Inc.
      Sanford FL
    • Matthew Devall
      December 20, 2016 at 12:27 PM
      Everyone,
      Thank you for your help.  First time I ever posted a questions and will not be the last.  Y’all are great!
      Matthew Devall
      Sulphur LA
The discussion ‘Power BI Months in Chart’ is closed to new replies.
