Positive Pay
  • Positive Pay
    Posted by DSC Communities on May 23, 2018 at 11:46 am
    • Paul Poulos
      May 23, 2018 at 11:46 AM
      I need to create a report to enable the bank’s Positive Pay feature that will be downloadable as a tab-delimited file that includes the following:
      1. Check #
      2.???? Check Date
      3. Check Amount
      4. Check Name
      In the past I was using the Vendor Check Register Report and then customizing it. Apparently the Payee on the report is truncated and does not agree with the Payee on the check. This is creating false exceptions when the bank matches the payee information to the file we uploaded. Is there a way to expand the check register so the information is not truncated? Or, is there an existing report for Positive Pay? Or, how can I create a report for each check run that can be uploaded?
      I look forward to your guidance
      Paul Poulos
      Hicks Nurseries Inc.
      Westbury NY
    • Matthew Arp
      May 23, 2018 at 12:06 PM
      ?, do you use the Safe Pay feature built into GP? This allows you to easily setup the appropriate file format for sending to your bank. Financial > Routines > Safe Pay
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
      May 23, 2018 at 12:48 PM
      ?Hi ?
      In GP, the “Positive Pay” functionality is called “Safe-Pay”.Ā  You basically set it up to match your bank’s format and then after pay runs or whichever time frame you agree with your bank on – you generate the file to a network location and then just upload it to your bank.
      Here are some instructions:
      https://support.microsoft.com/en-us/help/850752/steps-to-set-up-the-safepay-configurator-in-microsoft-dynamics-gp
      Microsoft remove preview
      View this on Microsoft >
      Kindest Regards,
      Jo deRuiter
      “That GP Red Head”
      Member, GPUG GP Credentialing Exam Committee
      “……what isn’t she up to?”
      Milwaukee, WI
      770-906-4504 (Cell)
The discussion ‘Positive Pay’ is closed to new replies.
