Pay run with W-4 and Supplemental Wages
  • Pay run with W-4 and Supplemental Wages
    Posted by DSC Communities on April 25, 2017 at 12:26 pm
    • Tamara Sullivan
      April 25, 2017 at 12:26 PM
      In April’s payroll, I’m processing taxable fringe benefits and payroll. The regular payroll is taxed using the W-4 and the taxable fringe benefits are taxed as supplemental wages using a flat tax rate of 25%. After calculating and reviewing, it appears that all wages and taxable fringe benefits are being taxed by the W-4 information. I’ve manually calculated the taxable fringe benefits and know the expected amount of tax at the 25%. However, the final federal withholding amount is about $50 less.
      Does GP allow for two different tax rates – one for a paycode and one for a benefit code? I want to verify that what GP is calculating is correct.
      Thanks for your help.
      Tammy
      Tamara Sullivan
      Senior HR Generalist
      H&W Computer Systems, Inc
      Boise ID
    • Tom Franz, CPP
      April 25, 2017 at 2:16 PM
      Tammy,
      Yes, Dynamics supports having a separate “Flat Tax Rate” for employee wages and benefits. On the Employee Benefit Maintenance window (which may be defaulted or rolled down from Benefit Setup), you can specify the 25% flat tax rate. The Calculate Checks process will then tax wages for the appropriate taxable benefit/pay code accordingly.
      Hope this helps!
      Tom Franz, CPP
      Client Engagement Manager
      Integrity Data
      Lincoln IL
    • Tamara Sullivan
      May 9, 2017 at 6:13 PM
      Hi Tom,
      Thank you for your assistance. I appreciate it very much. I think I have it working.
      Thanks again.
      Tammy
      Tamara Sullivan
      Boise ID
    DSC Communities replied 8 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Pay run with W-4 and Supplemental Wages’ is closed to new replies.
