I have a client that needs to upgrade to the latest version of Scribe as they integrate CRM to GP with Scribe. Ā The latest release for Scribe is going to install .NET 4.6.2. Ā I checked the documentation for GP 2015 and it says it requires .Net 3.5 and 4.5. Ā I would like to assume it won’t have any issues with a newer version of .Net? Anyone have any thoughts or experiences to share on this topic? Thanks
—————————— Donny Kensmoe Consultant Wipfli Green Bay WI ——————————
You should not, the 4.5/3.5 frameworks should already be installed as part of the GP client installation and the client specifies the framework version it uses.
—————————— Matthew Arp Business Systems Developer Hunton Group Houston TX —————————— ——————————————-
—————————— Donny Kensmoe Consultant Wipfli Green Bay WI —————————— ——————————————-
Rob Klaproth
April 19, 2017 at 10:44 AM
Yes it is compatible. Ā Management reporter CU15 actually requires it as well. Ā However you will still also need the older 3.5 and 4.5 versions that you already have installed as some code is not “forward” compatible with newer versions of .net. Ā Not sure why that is but it’s kind of annoying to think you need so many different versions of .net now days to make your applications work.
—————————— Rob Klaproth Sr. Dynamics GP Consultant Armanino San Diego CA —————————— ——————————————-
