Negative quantity on-hand
Posted by DSC Communities on April 4, 2019 at 3:25 pm-
Michael Beaupre
MemberApril 4, 2019 at 3:25 PM
We’re seeing a negative quantity on-hand (QOH) in our inventory in GP after doing an Inventory Adjustment.Ā Has anyone else seen a negative QOH?Ā Is there a way to prevent a negative QOH?——————————
Michael Beaupre
Systems Analyst
Connexus Energy
Ramsey MN
Charles Allen
MemberApril 5, 2019 at 9:42 AM
?There is an option in Inventory Setup for overriding quantities. Make sure that option is not enabled.——————————
Charles Allen
Senior Managing Consultant
BKD Technologies
Houston, TX
Josh Kenyon
MemberApril 5, 2019 at 10:32 AM
We see that happen occasionally and most of the time running the Inventory Reconcile on that particular item will correct it.——————————
Josh Kenyon
Automated Dairy Systems
Jerome ID
Michael Beaupre
MemberApril 5, 2019 at 1:13 PM
In Inventory Setup, we verified that the three Override check-boxes are unchecked and they are.Ā Might there be another Inventory Setup that we’re overlooking?We did these steps in an attempt to fix the negative Quantity on-hand (QOH) but no luck:
1.Ā Ran Checklinks against Inventory
2.Ā Ran PSTL Item Reconciler
3.Ā Ran PA Reconcile Item QuantitiesWe often have negative quantity ALLOCATED and then we run PSTL Item Reconciler and Reconciler fixes those.
Michael Beaupre
Systems Analyst
Connexus Energy
Ramsey MN
Katie Pieczynski
MemberApril 16, 2019 at 4:54 PM
Do you have any of those items allocated and if so when you click on the allocation link does it show an actual document number that it is allocated to?Ā This happens to us and it is actually the sales work table that we have to run check links on.——————————
Katie Pieczynski
Accounts Receivable Manager
DANSR
Champaign IL
Michael Beaupre
MemberApril 17, 2019 at 11:41 AM
Hi Katie,Ā
Thank you for your reply.Ā You say “when you click on the allocation link…”Ā On which screen does this allocation link appear?Ā Thank you.——————————
Michael Beaupre
Systems Analyst
Connexus Energy
Ramsey MN
Katie Pieczynski
MemberApril 17, 2019 at 1:20 PM
When you go into Item Inquiry and click the Allocated link it will open up another window and show you everything that Item is allocated to.Ā (SOP doc and Inventory transactions)Ā If there is nothing showing in the Item Allocation Inquiry screen then I would do a check links on sales work and then try reconciling the item.——————————
Katie Pieczynski
DANSR
Champaign IL
Michael Beaupre
MemberApril 18, 2019 at 4:31 PM
I’m with you now Katie.Ā I will experiment with this (in TEST).Ā Thank you for your post!——————————
Michael Beaupre
Systems Analyst
Connexus Energy
Ramsey MN
DSC Communities replied 6 years, 5 months ago 1 Member · 0 Replies -
The discussion ‘Negative quantity on-hand’ is closed to new replies.
