Missing Purchasing Dictionary
  • Missing Purchasing Dictionary
    Posted by Jeff Roe on October 19, 2017 at 3:05 pm
    • Jeff Roe
      October 19, 2017 at 3:05 PM
      Just acquired a new company and they are using GP 2015 R@ essentially out of the box with no customizations.
      We in the other day to run a Purchase Order Generator but didn’t see it in the list of option.
      Expected to see it at Transactions -> Purchasing -” Purchase Order Generator
      Went to Tools -> Setup -> Purchasing -> Purchase Order Processing and received a message “Cannot Access this form because the dictionary containing it is not loaded”.
      Any ideas and what dictionary would it be looking for?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Windi Epperson
      October 20, 2017 at 11:20 AM
      Jeff,
      Is there a chance that the other company used Project Acctg?Ā  Check out this post and see if it helps: Ā https://support.microsoft.com/en-us/help/916687/error-message-when-you-try-to-open-the-purchase-order-entry-window-in
      Windi
      Windi Epperson
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 Ext 102
    • Tim Andaya
      October 20, 2017 at 1:10 PM
      Hi Jeff,Ā
      I’m going to assume you have media; run the setup and maintain the current installation.Ā  Check to see which components have been installed.
      Check the registration and check to see which modules have been activated.
      Check the Dynamics.set file and compare it to the actual dictionary content in the application directory (usually c:Program FilesDynamicsGP2015 for 32 bit and C:Program Files (X86)DynamicsGP2015 for 64 bit).Ā  Note, that you may find dictionaries in the Data subfolder of the GP2015 root application folder, at least I have from time to time.
      Tim Andaya
      Strategic Systems Group
      “There are no stupid questions.”
    • Jeff Roe
      October 20, 2017 at 4:05 PM
      The issue has been resolved.Ā  The Automated PO Generator module was not checked as registered for their instance of GP.
      Jeff Roe
      Kele Inc
      Bartlett TN
    Jeff Roe replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Missing Purchasing Dictionary’ is closed to new replies.
