Mass changing item numbers
  • Mass changing item numbers
    Posted by Jeff Roe on April 18, 2019 at 1:23 pm
    • Jeff Roe
      April 18, 2019 at 1:23 PM
      We are going through a cleanup of inventory items and we have thousands of items where the GP Item number should be something other than what was originally created.
      I know that the PSTL tool has a function to modify a a GP Item Number to something else and does it against IV, SOP, POP etc. While this process may be sufficient for one off’s, it would likely take a great deal of time for thousands of parts.
      Has anyone created a SQL process to do this instead?
      I have identified what tables I think would need to be changed and have run against a single part and updated in IV, SOP, POP tables active and history and appears to have not hurt anything but am cautious to say it will work in a bigger scale.
      If I were to chose a SQL solution what else would I need to consider related to creating orphaned items or breaking GP business rules.
      BTW, the assumption would be that the new item number does not currently exist so there should not be any primary key or line item sequence related issues.
      Any help or thoughts is greatly appreciated.
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Kristen Hosman
      April 18, 2019 at 2:10 PM
      You can actually create a txt file to do mass changes.Ā  See instructions below.Ā  Let me know if you have any questions.
      To modify a range of Item Numbers via a spreadsheet:
      Create a spreadsheet
      Enter existing Item Number in first column
      Enter the new Item Number in the second column
      Save as a text file
      Start the PSTL function in Dynamics GP
      Select the Item Number Modifier option
      Click Next
      Select the Import option
      Select the Validate button
      Select the spreadsheet text file
      Select Open
      If no errors, Select the Modify button
      Kristen Hosman
      Dynamics ERP Consultant
      Mount Evans Consulting
    • Jeff Roe
      April 18, 2019 at 6:12 PM
      Sorry, I do know that I can do en mass with the PSTL tool but my concern is that to do thousands it would be a long process and much faster if I could use basic SQL.
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Andrew Kennedy
      April 19, 2019 at 6:44 AM
      Jeff,
      I would stick with using the PSTL tool.Ā
      I have a script that loops through information_schema table and finds all tables that have ITEMNMBR in it.Ā  But then realized that not all the tables with the item number are called ITEMNMBR.Ā  Such as the BOM component table CPN_I and PPN_I. Ā
      I believe the PSTL modifier is actually running SQL scripts, which is why you need to be sa or db_admin to run it.Ā  If you have a GP client on the server run it there off hours and it shouldn’t take much longer than running direct SQL.
      Andrew Kennedy
      Principal Consultant
      Velosio
      Seven Hills OH
    • Kristen Hosman
      April 19, 2019 at 10:21 AM
      You should break down the data into smaller chucks to see how long it takes.Ā  Also taking a backup before doing this is a great idea.
      I’ve done this before and it’s not as slow as you would think.Ā  As someone else noted using the PSTL tool will ensure that everything is updated correctly.
      Kristen Hosman
    • Blair Christensen
      April 19, 2019 at 10:02 AM
      Knew about the PSTL tool but didn’t know it could handle an entire list.Ā  I’m in this same boat and this would be awesome!Ā  Thanks!
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Aleiha Hanson
      April 19, 2019 at 11:25 AM
      you are a life saver! I never asked much about doing a bulk number of changes…thought about maybe doing it as a macro to save my typing and clicking. NO CLUE PSTL could handle an “import” to do a big list! I’m going to try it this weekend!Ā ?
      Aleiha Hanson
      Royal Basket Trucks, Inc – IT Manager
      GPUG Milwaukee WI Chapter Leader
      ahanson@royal-basket.com
    • Keith Koopmans
      April 19, 2019 at 9:38 AM
      Good morning –Ā
      You’ve received some great advice thus far but I’d just like to throw in another round of support for the PSTL tool.Ā  I’ve used the similar .txt method for an extreme amount of GL code combinations (thousands and thousands) and was pleasantly surprised regarding the speed.Ā  Some of these codes had thousands and thousands of prior uses.Ā  The inventory item numbers may exist in more tables, but again the PSTL tool was bulletproof.
      KEITH KOOPMANS
      GURTLER INDUSTRIES INC
      SOUTH HOLLAND IL
    • Bruce Strom
      April 22, 2019 at 10:18 AM
      You should be able to record a macro that uses the PSTL tool to update one inventory item,
      then use that to create a macro that updates all the inventory items.
      https://blogs.msdn.microsoft.com/developingfordynamicsgp/2008/10/29/how-to-use-word-mail-merge-and-macros-to-import-data/
      Bruce Strom
      Programmer Analyst
      Associated Grocers of Florida / Supervalu
      Sunrise FL
    Jeff Roe replied 6 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Mass changing item numbers’ is closed to new replies.
