Management Reporter – Reporting Tree Definitions Structure
  • Management Reporter – Reporting Tree Definitions Structure
    Posted by Michael-Connolly on September 8, 2017 at 5:07 pm
    • Michael Connolly
      September 8, 2017 at 5:07 PM
      ?Greetings!
      We have a Management Reporter question whichĀ I’m hoping someone has also encountered and/or has some knowledge about that they can share with us. One of our Finance staff created a reporting tree definition for another division (another GP company database) so they could see reports by divisions. The new reporting tree definition, Segment1 – SC, was added under (or in) a new folder called SC Division. When this was initially created, the Reporting Tree Definitions appeared like the following screen shot (with the Segment1 – TX division reporting tree definition under the top level folder, Reporting Tree Definitions.
      Seg1-TX Under Top Level Folder
      After this was saved, the Segment1 – TX division reporting tree definition was then positioned below (or in) the SC Division folder (as shown in the screen shot below). When the Segment1 – TX division reporting tree definition is moved back under the top level Reporting Tree Definitions folder by dragging it, it does not stay there even after saving.
      Has anyone else experienced the way the system handles this and, if so, has there been a way to overcome it? Is there a method we are overlooking or haven’t come across to where we can move the Segment1 – TX division reporting tree definition back under the top level Reporting Tree Definitions folder and have it stay there?
      All replies/responses are greatly appreciated!
      Mike Connolly
      ERP Admin
      MPS Group, Inc.
      Farmington Hills, MI
    • Steve Erbach
      September 8, 2017 at 5:30 PM
      >> it does not stay there even after savingĀ <<
      I’m not sure what you mean by that. I just tried moving a Tree Def from a folder up under the “Reporting Tree Definitions” using the right-click menu:
      Then the “Move Items” dialog appears and I select the top level and click OK:
      I don’t have to do anything else… that is, there’s no “save” step involved:
      What version of Management Reporter are you using?
      Sincerely,
      “Sparkly” Steve Erbach – Business Analyst & MS Dynamics Platform Administrator
      WOW Logistics Company – Appleton, WI
      VP for Communication, emeritus, GPUG WI (Milwaukee) Chapter
      GP 2016 (16.00.0439) / MR 2012 CU15
      Twitter: @serbach
      Welcome to Dynamics!
      You do not have permission.
      Call Steve.
      (hat tip: Lou Spevack)
    • Michael Connolly
      September 11, 2017 at 10:38 AM
      ?Good morning Steve and thank you very much for your reply!
      I have definitely tried using the Move item from the context menu. Although I am able to right click the report tree definition object and have it present the context menu with the Move item, when I click it and highlight the top level Reporting Tree Definitions folder then click OK it acts like it does it, but the segment definition remains under the SC Division folder.
      The only way I can visually get it to move under the top level Reporting Tree Definitions folderĀ is to drag it there with the mouse. When I do it this way, though, “it does not stay there even after saving.” After the save is done, the segment definition is moved (by the application) back under the SC Division folder.
      We have MR 2012, version 2.1.11002.5.
      Mike Connolly
      ERP Admin
      MPS Group, Inc.
    • Paul Gilmore
      September 11, 2017 at 7:22 AM
      Mike,
      Instead of dragging the tree division, simply rt click the division and select ‘promote’. Ā Does that provide a different result?
      Be sure you have THAT divisional Ā company set as the default company when making the move. Otherwise, MR won’t recognize the division.
      Let us know.
      Paul Gilmore
      Logan Consulting
      Chicago IL
    • Michael Connolly
      September 11, 2017 at 10:39 AM
      ?Good morning Paul!
      I had read on several of the blogs where I was trying to research this on how to use the “Promote” context menu item to do this. However, and I’m not entirely sure why, our installed instance does not have this context menu item available. Perhaps we’re running a few too many CUs behind.
      Here’s what I see in the context menu when I right click on the division definition objectĀ (no “Promote”)…
      Thank you very much for your reply!
      Mike Connolly
      ERP Admin
      MPS Group, Inc.
    • Joni Finnell
      September 12, 2017 at 12:13 PM
      ?Mike:
      If you select open on the menu that you showed so it will open the tree definition itself then right click on the segment that you want to move you should see the promote option.
      Joni Finnell
      GP Projects/Troubleshooter
      Newark OH
    • Steve Erbach
      September 12, 2017 at 2:41 PM
      “Promote” appears in the context menu when you’re editing a specific Tree Definition and you want to re-arrange the reporting units in your Tree to different places:
      It isn’t applicable to the directory listing of the Tree Definitions themselves. That’s what “Move” is for.
      One thing you might try: create a new folder (Test Division) in your “Reporting Tree Definitions” directory tree, and try to Move your Tree Def to the new folder. If that works, then I’d exit Report Designer and start it back up again. Then I’d try to move your Tree Def up to the root level.
      I think that your best bet is to upgrade MR to a more current release. The most recent is CU16. You’ll want to get help from your Partner since there have been database changes.
      Sincerely,
      Twitter: @serbach
      Call Steve.
    • Derek Krebs
      September 11, 2017 at 10:40 AM
      ?Hi, yes agree with Steve that a “Move” or drag and drop the tree into a given folder of the Tree Definitions list is how trees get organized.
      Derek Krebs
      Sr Consultant
      MSX Group
      derek.krebs@msxgroup.com
    • Michael Connolly
      September 14, 2017 at 8:43 AM
      ?Hello again everyone,
      IĀ very muchĀ appreciate everyone’s replies! Everything suggested has (and had been) tried, but the report tree definition will not stay in the top level folder. The exception was that I did not find the “Promote” menu item anywhere in our system. I thought, perhapsĀ that thereĀ may have been something I was missing in order to get this to work. It appears that I will need toĀ set up a test environment with a freshly installed instance of MR. I’m not sure why our production system will not work as suggested and doesn’t have the Promote function available, so this will provide me with a better environment to research and test in.
      Thanks again!
      Mike
      Mike Connolly
      ERP Admin
      MPS Group, Inc.
    • Steve Erbach
      September 18, 2017 at 12:43 PM
      Again, the “Promote” option only appears when you’re editing a specific Tree Definition and you want to change the indentation level for a branch of the Tree. The only way to change the location of a Tree Definition as a whole in the Tree Def directory structure is via the “Move” option… or by dragging.
      Twitter: @serbach
      Call Steve.
    Michael-Connolly replied 8 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Management Reporter – Reporting Tree Definitions Structure’ is closed to new replies.
