is GPConnNet.dll support GP2016
  • is GPConnNet.dll support GP2016
    Posted by DSC Communities on December 13, 2016 at 6:06 am
    • NaveedAli Ali
      December 13, 2016 at 6:06 AM
      Does GPConnNet.dll support GP2016 ?
      because in our case it is crashing the GP when we include in Addins folder..
      Naveed Ali
      Technical Lead
      Evincible Solutions LLC
      Houstan TX
      8325866423
      naveedali.dewa@gmail.com
    • Bruce Strom
      December 13, 2016 at 9:41 AM
      This is where GPConnNet.dll goes:
      C:Program FilesCommon FilesMicrosoft SharedDexterityv2.0
      Bruce Strom
      Programmer
      Associated Grocers of Florida
      sunrise FL
    • Ramkrishna Shenkar
      December 27, 2016 at 4:53 AM
      Hello NaveedAli Ali,
      I am also facing this issue with GPConnNet.dll for GP 2016R2. Did you get any solution for this?
      Ramkrishna Shenkar
      Sr. Software Developer
      Avalara
      Seattle WA
    • Rob Klaproth
      December 27, 2016 at 5:44 PM
      I’m assuming you’re referring to Frx.  šŸ™‚
      You can’t use the GPConn.dll file from GP 2015 or 2016.  You need to find an older copy of GP (2013 or older) and copy the file over to:
      C:Program Files (x86)Common FilesMicrosoft SharedDexterity
      ——Original Message——
      Ramkrishna Shenkar
      Avalara
      Seattle WA
    • Leslie Vail
      January 2, 2017 at 6:33 AM
      I’ve got GP 2016 R2 running against FRx 6.7 all over town. The GPConn dll does need to be replaced with an older version in order to have it run. We also needed to do this with GP2015. You can create the GPConn.dll by running the frxReg67.cmd file. This file is located in the Frx folder. Rename your current GPConn.dll file before running the frxReg67.cmd file.
      Kind regards,
      Leslie
      Leslie Vail
      Dallas TX
    • NaveedAli Ali
      January 2, 2017 at 5:59 PM
      Dear Ramkrishna,
      I tried new installation of GP2016 on fresh machine but problem didn’t solved, so i picked the file from my client machine and use it in my project , it is working fine..
      If you still facing problem , let me know you email address so i will send you file.
      Naveed Ali
      Technical Lead
      Houstan TX
      8325866423
    DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘is GPConnNet.dll support GP2016’ is closed to new replies.
