Invoices & TImesheets
Posted by DSC Communities on August 27, 2019 at 1:23 pm-
Jody Brockman
MemberAugust 27, 2019 at 1:23 PM
We are using GP2010 to do invoicing and BBO for timesheets. Currently, the finance team prints out all of the invoices from GP, then pronts out all of the timesheets from BBO. Puts the correct timesheet with the matching timesheets for each client and then scans them in to create PDF that can be emailed that includes the timesheets and the invoices.Ā
I am new to both GP and BBO, but there HAS to be a better way to do this.Ā
We are a CA based company and require time-in/time-out timesheets… which is why we cannot use the timesheets in GP.ĀHas anyone faced something similar and found a solution?Ā
Thanks!Ā——————————
Jody Brockman
Ascent Services Group
Concord CA
Charles Allen
MemberAugust 28, 2019 at 1:36 AM
Can you get to the data in BBO? One idea is to use SQL Server Reporting Services to create invoices which pull data from both systems.
Charles Allen
Senior Consulting Manager | BKD
2700 Post Oak Blvd. Suite 1500
Houston, TX 77056
713.499.4629 Direct
713.494.2104 Mobile
****** BKD, LLP Internet Email Confidentiality Footer ******Privileged/Confidential Information may be contained
in this message. If you are not the addressee indicated in
this message (or responsible for delivery of the message
to such person), you may not copy or deliver this message to
anyone. In such case, you should destroy this message, and
notify us immediately. If you or your employer do not consent
to Internet email messages of this kind, please advise us
immediately. Opinions, conclusions and other information
expressed in this message are not given or endorsed by my
firm or employer unless otherwise indicated by an authorized
representative independent of this message.Any tax advice contained in the body of this email was not
intended or written to be used, and cannot be used, by the
recipient for the purpose of avoiding penalties that may be
imposed under the Internal Revenue Code or applicable state
or local tax law provisions.These discussions and conclusions are based on the facts
as stated and existing authorities as of the date of this
email. Our advice could change as a result of changes in the
applicable laws and regulations. We are under no obligation
to update this information if such changes occur. Our advice
is based on your unique facts and circumstances as you
communicated them to us and should not be used or relied
on by anyone else.——Original Message——
Thanks!Ā——————————
Jody Brockman
Concord CA
Rebeccah Grimes
MemberAugust 28, 2019 at 9:30 AM
Good morning!I wrote a long thing about how my company utilized Integration Manager to import time sheets from an external system, but re-reading your question it looks like what you need is a watched folder!
“An administrator can configure a network folder, known as aĀ watched folder, so that when a user places a file (such as a PDF file) in the watched folder, a pre-configured operation is started and manipulates the file.” -from Adobe’s website, but they aren’t the only option
There are lots of software and programmatic options to make this happen, but essentially invoices go in one folder named with an identifier and time sheets go in another folder with the identifier to match to appropriate invoice, code matches and combines them into a new pdf.
You probably already own software that can do this, and it is just a matter of setting it up. If not, there are solutions to fit any budget.
Hope this helps!
Rebeccah——————————
Rebeccah Grimes
Application Specialist, MS Dynamics GP
Tech24
A Commercial Foodservice Repair, Inc Company
Good morning, Jody.Ā
I don’t like to make assumptions so I just wanted to clarify.Ā When you say BBO, you are referring to Bullhorn Back Office? If so, it sounds like you are in the staffing industry?Ā Would you mind me asking who your partner is?Ā
If I have the information correct, I can provide more information.Ā If it’s incorrect, then at least I am not wasting any of your time. šĀ
Thank you!
Jamie Evenson
CEO
Najaxa Software
Las Vegas, NV
Jody Brockman
MemberSeptember 3, 2019 at 12:54 PM
Thanks for all of the great ideas!
@Jamie Evenson – Yes, we are using Bullhorn Back Office and we are a staffing company. We use JobDiva for our ATS, though.
Thank you!
Jody
Jody Brockman Sr Innovation Architect Ascent D: 720-573-5266 M: 303-517-6862 Email: jbrockman@ascentsg.com Web: http://www.ascentsg.com
8055 E Tufts Ave
Suite 850
Denver, CO, 80237Linking Talent with Opportunity
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission. If verification is required please request a hard-copy version.
This email has been scanned for email related threats and delivered safely by Mimecast.
For more information please visit http://www.mimecast.com
Thank you!
Jamie Evenson
CEO
Najaxa Software
Las Vegas, NV
Hi Jody,
Liaison Messenger EDD can automate this whole process for you. Messenger EDD can archive copies of your time sheets coming out of your BBO software if that product does not have that capability already. We will use data off of the time sheet to assign a name to each PDF created.Ā
When you print your invoices in Dynamics GP, Messenger EDD will use data on the invoice to retrieve the proper time sheet from the archive folder, merge it with the invoice and then email it to the customer. No training for the end use is necessary. The end user just prints through their existing print procedure in GP with the only change is that they now print with the Messenger EDD print driver.Ā
The time sheets can also be archived together with the invoices. This PDF(invoice/timesheet) can later be attached to the statement when statements are created.
Here is a link to more product information on our website.
https://www.liaisonsc.com/liaison-messenger-edd
Please reach me at 800.811.4618 x201 if you have any other questions or if you’d like to schedule an on-line demonstration.
Tom Nielsen
Liaison Software
800.811.4618.x201
tom@liaisonsc.com
http://www.liaisonsc.com——————————
Regards,Thomas Nielsen
Sales Manager
Liaison Software Corporation
Santa Ana CA
714-543-9877 x201
tom@liaisonsc.com
DSC Communities replied 6 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘Invoices & TImesheets’ is closed to new replies.
