Yes, you can sort your invoice differently – assuming you are talking about the item lines. I’ve done this recently using the line comment field as well as from an Extender field. You need to first modify the sort in Report Writer, then update your Word Template using the XML from the GP standard report and then your report should sort as expected. A tip – do your testing on the standard report first as it may save you from applying the changes via XML several times during the process. Good luck!
—————————— John Kirsch Senior Consultant Wipfli Green Bay —————————— ——————————————-
