Integration mannager – error message ‘ Could not update :currently locked”
  • Integration mannager – error message ‘ Could not update :currently locked”
    Posted by DSC Communities on May 8, 2019 at 2:47 pm
    • Phuong Nguyen
      May 8, 2019 at 2:47 PM
      we are running into an issue , all our user got into the error message below ” could not update: currently locked”Ā  while using integration Manager. Please advice
      phuong nguyen
      ACC
    • Blair Christensen
      May 9, 2019 at 10:23 AM
      That is usually a message from the database engine saying that two processes are competing over which one gets to modify records.Ā  Its unusual to see because the only way it should be happening is if you have one process open as a transaction that is waiting for the transaction to close (and be made final) and another transaction comes along at the same time.
      You need to find out what other process is trying to change something and allow it to complete.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Ryan Galang
      May 9, 2019 at 12:28 PM
      Hi Phuong,
      Can you please check if your integration* is using a “Database” Storage Type?
      * Right click on the Integration file (e.g. Bank Reconciliation) >>Ā  (Bank Reconciliation) PropertiesĀ  >> Logs tab >> [change to File, edit path] >> Apply
      If yes, see if setting this to “File” (and assigning a corresponding path that both users have access to) stops the error from coming up?
      integration manager
      Ryan Galang
      BTP Technologies LLC
      Chantilly VA
    • valerie nguyen
      May 8, 2020 at 2:43 PM
      Ā  we got below error message after running the integration managerĀ ?. we could see the batch in GP after import. how could we fix this error message. i double check on logs – it is “database” as storage type. Please advice
      valerie nguyen
      System Integration Analyst
      ACC
      Irvine CA
    • Blair Christensen
      May 8, 2020 at 3:51 PM
      In GP, have someone (with the appropriate privileges) open up the User Activity window (Dynamics GP -> Tools -> Utilities -> System -> User Activity) and see who else is in the company associated with your integration.Ā  Have them log out of the company long enough to do the following test:
      1. Delete the batch of entries created by the run displaying errors.
      2. Run the integration again (after verifying no one is in the company in question)
      3.Ā  See if the error is resolved.
      The contention is being caused by some other process trying to access the records in question.Ā  This can be another user in GP or even a long-running report in some cases.Ā  If this doesn’t result in success, check and see if there are any AFTER INTEGRATION scripts associated with the integration which might be causing data mutation (data edit by multiple simultaneous processes).Ā  If still nothing there, it becomes a lot harder because you’ll have to get a DBA involved to do trace statements and find out what two processes are conflicting.
      Blair Christensen
    DSC Communities replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Integration mannager – error message ‘ Could not update :currently locked”’ is closed to new replies.
