Integration Manager freeze (Crash) after importing process at 100%
  • Integration Manager freeze (Crash) after importing process at 100%
    Posted by DSC Communities on May 7, 2019 at 6:36 pm
    • Phuong Nguyen
      May 7, 2019 at 6:36 PM
      we are running into an issue after we run Integration Manager at 100% complete, the IM was crash ( frozen). i have to use task manager to skill the application and run again. it happened for 1 user account, not the other user in GP server. I am not sure what cause the issue ? Please advice
      phuong nguyen
      acc
    • Chris Donnelly
      May 8, 2019 at 8:09 AM
      Phuong,
      I have seen this before.  Try turning off Connect on the user’s homepage:
      Turn off Connect on homepage
      Chris
      Chris Donnelly
      Sr Mgr of Info Systems and Financial Reporting
      Healthmark Industries
    • Phuong Nguyen
      May 8, 2019 at 2:06 PM
      Thanks Chris for your response. the original set up has already unchecked ‘Connect’; but the issue is still exists. Please advice
      phuong nguyen
      ACC
    • Phuong Nguyen
      May 8, 2019 at 2:21 PM
      Thanks Chris.the connect box is uncheck , but the issue is still there.  Is there any other solution ? Thanks
      phuong nguyen
      ACC
    • Chris Donnelly
      May 8, 2019 at 3:03 PM
      The next thing I would try is to turn off the Action Pane for the user.  This is in Microsoft Dynamics GP > User Preferences.
      Set it to Menu Bar.  Have the user log out and then log back in.
      UserPreferences
      Chris
      Chris Donnelly
    • Phuong Nguyen
      May 8, 2019 at 3:33 PM
      ??Thank Chris. it did not make any different. we got the other error message ” Could not update : currently locked” as below screenshot. Please advice
      phuong nguyen
      ACC
    • Chris Donnelly
      May 8, 2019 at 3:56 PM
      Hey!  That’s progress!
      Now you’re getting an error message.
      Here are a few more things to look for or to try…
      – Relocate your source file to the user’s local machine (if it’s not already).
      – Look for anything that may be trying to connect to your source file (other users, other connections, etc.).
      – Look for tasks in your Integration.  There may be a task that runs at the end of your Integration that is getting stuck.
      – Compare all of the ODBC connections on the failed user to a good user.
      – Be sure there is only one instance of GP running on the user’s machine.  A reboot may help.  Is this a Citrix or Terminal Server environment?
      – Look in the event viewer for more error messages.
      Chris
      Chris Donnelly
    • Phuong Nguyen
      May 9, 2019 at 1:48 AM
      Thanks Chris .
      everyone is using GP through Citrix server.
      if 2 users are using the integration at the same time, it would cause the issue ? i will try to see if we are able to move source file to local server . since source file is located at share drive to all user to access right now . but we have never seen this happen before. this is really strange
      phuong nguyen
      ACC
    • Chris Donnelly
      May 9, 2019 at 8:09 AM
      Ahhh Citrix.  This is a different animal.  First, I would look for any differences in the user’s profiles.
      Here’s another completely different approach you may want to take…   there are two ways to install/configure Integration Manager.  The simple way is probably what you have.  When you launch Integration Manager this way, it ‘takes command’ of the user’s interface and emulates the keystrokes a user would do (sort of).  The other method is to configure Integration Manager to use eConnect.  This method does not use the user’s interface.  It will execute stored procedures to update your database directly (sort of).
      This may eliminate issues with sessions, profiles and the GP interface.
      Chris
      Chris Donnelly
The discussion ‘Integration Manager freeze (Crash) after importing process at 100%’ is closed to new replies.
