How to run GP as Administrator in Citrix Environment
  • How to run GP as Administrator in Citrix Environment
    Posted by Donny Kensmoe on May 18, 2018 at 6:03 pm
    • Donny Kensmoe
      May 18, 2018 at 6:03 PM
      I have a client that can only launch SSRS reports successfully if they Run GP as Administrator. The problem is they are in a citrix environment and do not have the option to Run GP as Administrator.Ā  Anyone know a workaround for this to force it where GP will always Run as Administrator? Thanks
      Donny Kensmoe
      Consultant
      Wipfli
      Green Bay WI
      May 19, 2018 at 9:17 AM
      ?Hi
      It may not be that GP is the issue.Ā  Since it launches in IE, you can have IE run as administrator (or Chrome).Ā  To launch IE always as administrator, ?select “Open File Location” to locate the network shortcun in File Explorer, right-click this shortcut, select Properties:Advanced, Run As Administrator and then OK out of it.
      If it’s launching in Chrome try setting Chrome to always run as administrator by doing the same thing.
      If it’s not that, was SSRS set to launch from a port other than 80?
      Kindest Regards,
      Jo deRuiter
      “That GP Red Head”
      Member, GPUG GP Credentialing Exam Committee
      “……what isn’t she up to?”
      Milwaukee, WI
      770-906-4504 (Cell)
    • Zubin Gidwani
      May 21, 2018 at 3:51 AM
      Recent issue last week or on going issue. We are finding similar issues with our program after Windows latest patch last week.
      It seems to be elevated UAC controls…
      Zubin Gidwani
      Founder
      Dynamic Budgets
      Danville CA
    • Donny Kensmoe
      May 22, 2018 at 8:29 AM
      Zubin,
      This is a recent issue that cropped up last week. Do you happen to know which Windows update is the culprit?Ā  I could suggest that they uninstall the update and see if the issue goes away. Thanks for your help.
      Donny Kensmoe
      Consultant
      Wipfli
      Green Bay WI
    • Thaddeus Suter
      May 22, 2018 at 8:39 AM
      Donny,
      The issue is your Citrix sever does not have its most recent Windows OS updates but the windows 10 clients do. Probably set to auto update. Now they are inconsistent.
      You may also see permissions errors just connecting to the published apps. RdWeb seems more sensitive to the issue than XenAp.
      The best approach is to get your Citrix server(s) updated. If they are Win server 2012 or later.
      Or you can uninstall the updates on the Win 10 clients. But they will keep coming back.
      The culprits areĀ KB4103718 / kb4103727 / KB4093942 /kb4103721.
      Most these updates were around May 9-10, 2018.
      Look in your Updates History for the dates under Windows on the problem client(s).
      Thaddeus Suter
      Retus, Inc
      HELOTES TX
    Donny Kensmoe replied 8 years, 6 months ago 1 Member · 0 Replies
The discussion ‘How to run GP as Administrator in Citrix Environment’ is closed to new replies.
