Exchange Rate Feed Software
  • Exchange Rate Feed Software
    Posted by Shari Bruno on August 15, 2018 at 10:59 am
    • Shari Bruno
      August 15, 2018 at 10:59 AM
      ?Good Morning!
      For those who are multi-currency, do you use exchange rate feed software to populate rates in your currency tables? If so, what software do you use, and where are they getting the rates?
      We use Olympic and got rates through ComFex for several years, but switched to Yahoo about a year ago. Unfortunately Yahoo stopped working, and the alternatives provided to us by Olympic don’t meet our needs due toĀ our large number of exotic currencies and currencyĀ pairs.
      Any and all information is greatly appreciated.
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Windi Epperson
      August 15, 2018 at 12:33 PM
      Hey
      Check out http://envisagesoftware.com/exchange-rate-feed-for-dynamics-gp/
      We looked at this for a customer recently and we were really happy with the pricing and it can import from several different services.
      Windi?
      Windi Epperson
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 ext. 102
    • Silver Subie
      I implemented this solution 5-6 years back. We only had 5-6 different currencies and it worked well.Ā  If you accept Google Finance feed, it should work for you.Ā  I can’t remember how many different feeds they have, at least 3 at the time I used.Ā  Check w them.Ā Ā
      https://www.expsoltech.com/downloads/GP_MC/GP%20Xchange%20Rate%20Feeder_User%20Manual.pdf
      Expsoltech remove preview
      View this on Expsoltech >
    • Shari Bruno
      August 15, 2018 at 1:10 PM
      ?Thanks and !
      Our partner mentioned Envisage and I will check into Expsoltech too.
      A question for the two of you, are you valuing exotic currencies? The majority of the 46 currencies we need to value are exotic, mostly from Africa and SE Asia. ?Our biggest roadblock has been finding a service that can provide those rates.
      Shari Bruno
      Crete, IL
    • Silver Subie
      August 15, 2018 at 1:50 PM
      No, only CAD, pounds and Middle East currencies.
      I do remember the software itself is flexible where you could define/add the feed; Or, ask them to change/add the feed for you. I thought we were using Oanda feed back then but couldn’t remember.Ā  I need to take it easy on single malt ;-)——————————————-
    • Shari Bruno
      August 15, 2018 at 3:01 PM
      I need to take it easy on single malt šŸ˜‰
      Silver Subie,Ā Ā 08-15-2018 01:50 PM
      At least during the workday Ā  šŸ™‚
      Shari Bruno
      Crete, IL
    • Kim Peterson
      August 16, 2018 at 8:39 AM
      I’m most familiar with Olympic Systems.
      But MVP Mohammad has written one that could help you.
      Kim Peterson
      218-862-5002
      Kim@DynamicsConnections.com
      #KimPetersonGP
    • Maria Frandzeskakis
      August 15, 2018 at 2:33 PM
      Hi ,
      We’re also using Olympic, with the Bank of Canada rate feed.
      This is the link in case it helps:
      Daily Exchange Rates
      Kind regards,
      Maria Frandzeskakis
      MIP Inc.
      Anjou QC
    • Shari Bruno
      August 15, 2018 at 3:03 PM
      ?Thanks , I will look into Bank of Canada as well.?
      Shari Bruno
      Crete, IL
    • Windi Epperson
      August 15, 2018 at 3:46 PM
      Not sure about exotic rates, but the info I have from envisage says:
      Exchange rates can be sourced from a number of free currency web service sites. Alternatively, you can connect the application to a paid subscription web service like http://www.xe.com/ or http://www.oanda.com/Ā Ā
      I looked at those two sites and they have on-website-converters that have a ton of rates so maybe that will give you a glimpse into what rates they facilitate.
      Windi?
      Windi Epperson
      Norman OK
    • Andrew Dean
      August 16, 2018 at 3:15 AM
      Hi Shari
      The Exchange Rate Feed from Envisage can connect to the following free currency services
      –Ā Ā http://api.openrates.io/latest?base={0}
      –Ā Ā http://free.currencyconverterapi.com/api/v3/convert?q={0}_{1}&compact=y
      –Ā Ā http://www.bankofcanada.ca/valet/fx_rss/FX{0}CAD
      Note: in the URL examples,Ā  replace {X} values with relevant ISO currency code.
      There are two subscription sites the application can connectĀ to (www.oanda.com and http://www.xe.com) but these have expensive monthly subscription fees.
      Some new currency subscription sites are now coming online that convert all currencies and are reasonably priced.Ā  ( ie.Ā  https://fixer.io/productĀ )Ā
      Hope this information helps.
      Andrew Dean
      Envisage Software
    • David Morinello
      August 16, 2018 at 8:45 AM
      ?Also, some banks will provide this data to you free of charge, if you ask. I have an FTP job pull a small text fileĀ from BOA nightly and consume it using SmartConnect into GP.Ā  169 different country currencies, although we only use GBP at the moment.
      When you have a hammer (SmartConnect), everything starts to look like a Nail.
      David Morinello
      Ascend Learning, LLC
      Leawood KS
    • Shari Bruno
      August 16, 2018 at 12:43 PM
      ?Wow! Thank you everyone, so much great information to check into. I appreciateĀ all of your expertise!!
      Shari Bruno
      Crete, IL
    Shari Bruno replied 7 years ago 1 Member · 0 Replies
The discussion ‘Exchange Rate Feed Software’ is closed to new replies.
