Error enter a part on a Sales Order
  • Error enter a part on a Sales Order
    Posted by Jeff Roe on August 28, 2017 at 1:57 pm
    • Jeff Roe
      August 28, 2017 at 1:57 PM
      I have a part that I’m struggling adding to a Sales Order.
      After the part number is entered and I tab through the fields on the line details, I get a UOM value, Unit Price and Extended Price just as expected. When I tab out of the Extended Price field the system displays a message “Not all required fields have been entered. Required fields appear in bold black type”
      It is part specific because all other parts work fine. Ā What should I be looking at and in what tables to validate where the part is incomplete?
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Frank Heslin
      August 28, 2017 at 2:08 PM
      Hi Jeff,
      One thing to look out for is case sensitivity.Ā  You may have a U of M setup for that part with a different spelling (case) than what is most likely auto-populating when you start typing in that field.
      For example:Ā  EACH <> Each <> each
      Check the specific U of M for that part.
      It used to happen to me a lot back in the dayšŸ˜‰
      Frank Heslin
      ExamWorks, Inc.
      Atlanta GA
      Member, GPUG Advisory Committee
      Summit Track Leader
      GPUG All Star 2016
      GP2015 R2
      MR CU14
      Follow me on Twitter: @Automate_It
    • Andrew Collins
      August 28, 2017 at 2:38 PM
      Jeff,
      I also got tripped up by this message recently, the cause of my issue was no Price Level assigned to that Item Number. Ā This can be added as a default in the Price List (Standard Pricing) for that Item Number, or you can add an existing Price Level directly on the Sales Order Line. Ā To see the Price Level field you will need to expand on the line using using the “chevron” button in the top right of that section of the window.
      Andrew Collins
      Senior Consultant
      Socius
      Dublin OH
    • Jeff Roe
      August 28, 2017 at 3:19 PM
      The part in question has a correct Price Level the same as other parts that work OK.
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Jeff Roe
      August 28, 2017 at 3:32 PM
      Correction, i was looking at the wrong Price Level.
      After going to the right area the part did in fact not have a Price Level.
      It was added and all is well.
      Jeff Roe
      Kele Inc
      Bartlett TN
    • Jeff Roe
      August 28, 2017 at 2:39 PM
      I had already validated that but thanks anyway, it never hurts to be sure.
      All our parts are setup as EA
      Jeff Roe
      Kele Inc
      Bartlett TN
    Jeff Roe replied 8 years ago 1 Member · 0 Replies
The discussion ‘Error enter a part on a Sales Order’ is closed to new replies.
