Entering Purchase Orders for non-inventory items
  • Entering Purchase Orders for non-inventory items
    Posted by DSC Communities on October 30, 2018 at 2:59 pm
    • Patti Skaleski
      October 30, 2018 at 2:59 PM
      Hi All
      Does anyone enter Purchase Orders for non-inventory items? Ā (ex) Limited use marketing materials, etc.
      I would like to be able to run a smartlist of items on order, provide a PO number to the
      vendor and have an order history in GP without creating an item card for everything.Ā
      Any information would be greatly appreciated.
      Thank you,
      Patti Skaleski
      Terry Naturally/Europharma
      955 Challenger Dr
      Green Bay, WIĀ  54311
      Patti Skaleski
      Inventory/Purchasing
      Europharma Inc.
      Green Bay WI
    • David Hatfield
      October 30, 2018 at 9:36 PM
      Hi Patti,
      Yes, you can create enter non-inventory items on a PO.Ā  When you enter an Item ID, if the Item ID does not exist in Inventory, then GP recognizes it as a non-inventory item.Ā  So, every line item needs an Item ID, but the Item ID does not have to exist in inventory.Ā  I recommend that you enter a short name in the Item ID and then a longer description in the Item Description field.Ā  You can enter the default expense account in the item detail window.Ā  This account will be used when you match the invoice to the PO.Ā  You can then use the Purchase Line Items Smartlist to view line item history with PO numbers and Vendor information.
      Please let me know if this information was helpful.Ā  I am also available to connect via GoToAssist, free of charge, to help you resolve any GP issues.
      David
      #PurchasingĀ #SmartListĀ
      David Hatfield
      CEO, Vital Partners, LLC
      david@vp.care
    • Shari Bruno
      October 31, 2018 at 10:27 AM
      Hi?
      ?For service POs we created non-inventory items such as Advertising, Mailing, etc but started the Item ID with X- to group them together: X-Advertising, X-Mailing, etc.Ā
      We created Drop Ship POs that used these items, and Enter/Match Invoice for processing.
      If we expected to receive multiple invoices against the PO we would use the total dollar amount as the Quantity, and $1.00 as the Unit Cost. So a $10,000 total cost would have 10,000 units of $1. If a $500 invoice was received we wouldĀ  Enter/Match Invoice for 500 units, or whatever the amount was including change.
      In SmartList, Purchasing, Purchase Order Lines you can create a report for item IDs that start with X-, or whatever naming convention you decide, and include PO number, etc as needed. What you can’t do is get a report of what is received. If you need that type of information then you need to create inventory items and create Standard POs.
      One note on the Item IDs, we used a handful of service Item IDs and used the Description to add more detail. We then added the Description field to the SmartList.
      Last note – I’m saying this in past tense because we had to change our process when we implemented Requisitions through ReQlogic. But for 13 years we used the process above and it served us well.
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Patti Skaleski
      October 31, 2018 at 10:37 AM
      Thanks @DavidHatfieldĀ and @ShariBruno
      I will try a couple test PO’s and then will probably have
      a couple more questions.?
      Patti Skaleski
      Europharma Inc.
      Green Bay WI
    • Ben Litjen
      October 31, 2018 at 11:42 AM
      One of the key benefits to using one of the better add-on requisition/PO solutions is their ability to easily handle non-inventory items. eRequester, Paramount, Reqlogic all handle this really well and have a ton of other benefits beyond using the native GP PO module. I obviously have a preference as to which is best but would recommendĀ you take a look at all the options in addition to what is native in GP.Ā
      Best,
      Ben Litjen
      CEO
      eRequester
      (206) 256-0771 x112
      benl@erequester.com
      Seattle WA
    DSC Communities replied 6 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Entering Purchase Orders for non-inventory items’ is closed to new replies.
