Electronic Check Signatures
  • Matthew Schwankl
    July 18, 2023 at 4:01 pm
    We use the software and it does a good job. We too have two signatures on each check and Merkorma is able to handle it. Fairly easy software to setup. Haven’t had any issues with it. We’ve used it on several GP databases in the past and you can setup a check template for each database. We also have used it in the past in a single database that uses Binary Stream’s MEM and was able to setup check template per entity within the database. We still use it in MEM after converting over to Centralized AP.
    • Sandy Browner
      August 4, 2023 at 10:28 am
      Thanks Matthew! I appreciate the feedback.
  • Kevin Pritchard
    August 7, 2023 at 1:53 pm
    Hi Sandy,
    I work for an ISV called Fidesic that offers this such service. We have web based approvals, and can apply a signature to the check (including multiple signatures) of the person who actually did the approval.
    If you need less than 3 users we could set you up with the free version and you could use it for as long as you like at no cost.
    You can check it out here if you are interested, and feel free to reach out to me on here or on linkedin if you have any questions: https://www.fidesic.com/product/vendor-payments
The discussion ‘Electronic Check Signatures’ is closed to new replies.
