dex.ini SQLCursorBlockSize and SQLQueryTimeout
  • dex.ini SQLCursorBlockSize and SQLQueryTimeout
    Posted by jim.harris@examworks.com on January 29, 2020 at 11:07 am
    • Jim Harris
      January 29, 2020 at 11:07 AM
      Is there a brave soul out there who has played around with these two dex.ini settings – SQLCursorBlockSize and SQLQueryTimeout?Ā
      From Leslie Vail’s excellent collections of dex.ini switches https://dynamicsconfessions.blogspot.com/2014/02/dexini-switches-my-complete-list.html
      these are defined as:
      SQLCursorBlockSize=100Ā Removing this setting To prevent the Loop stopping at 25 records when looping through a range of records with Dexterity.
      SQLQueryTimeout=0 Including this setting in your DEX.INI file will control the period of time Dexterity will wait for a SQL query to execute. When set to 0 it will wait indefinitely. A valid range of values for this setting are 0 to 9999. If this setting is not included, the default value is 300 seconds.
      I’m curious what the practical impacts are with both of these.Ā
      Could increasing the cursor block size improve performance in an environment with high POP, PM, SOP and AR transaction volumes?Ā Ā
      Does the query timeout setting come into play on inquiry windows in GP?Ā  If not there, then where?
      Jim Harris
      ExamWorks, Inc.
      Atlanta GA
    jim.harris@examworks.com replied 6 years, 9 months ago 1 Member · 0 Replies
The discussion ‘dex.ini SQLCursorBlockSize and SQLQueryTimeout’ is closed to new replies.
