Deposit in GL but not Check Register
  • Deposit in GL but not Check Register
    Posted by DSC Communities on November 14, 2017 at 11:06 am
    • Kelley Karl
      November 14, 2017 at 11:06 AM
      Is there a way to record a deposit directly to the check register?Ā  The transaction originated in Sales and the customer is good, it has a GL transaction but no deposit in the check register.
      Kelley Karl
      Professional Assist Corp
      Golden CO
    • Kristen Hosman
      November 14, 2017 at 11:34 AM
      Hi ?
      Sounds like the Bank Deposit hasn’t been done yet…that will update your checkbook.Ā  Transactions > Financial > Bank DepositĀ
      Select the transaction to deposit then post.
      Let me know if that works for you.Ā  If not I’ll explain the fix.
      Kristen Hosman
      Accounting Manager
      PlatinumCode
      Pine CO
    • Kelley Karl
      November 14, 2017 at 1:44 PM
      There isn’t one there.Ā  Should I just void the transaction in Sales and start over?
      Kelley Karl
      Golden CO
    • Windi Epperson
      November 14, 2017 at 3:56 PM
      Kelley,
      Any chance the cash was received into the wrong checkbook?Ā  If you go to Transaction by Customer inquiry and drill back on the payment, you should be able to see the checkbook (unless you’re on an older version of GP).Ā  I would check that first.
      Windi
      Windi Epperson
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 Ext 102
    • Kelley Karl
      November 15, 2017 at 11:16 AM
      Thanks Wendi for your suggestion.Ā  @KristenĀ Hosman looks like I need the fix.Ā  How does this happen??
      Kelley Karl
      Golden CO
    • Windi Epperson
      November 16, 2017 at 10:16 AM
      Hey
      You can go to Bank Transactions and enter either a Receipt or an Increase Adjustment.Ā  Since you said you can see the deposit in the GL, then you would just code the transaction to debit and credit the cash acct.
      If you do a receipt then you’ll have to go to Bank Deposit after posting the receipt to finish the process.Ā  If you use an Increase Adj, you won’t have to go deposit but it will show in a different area when you do the recon.
      Windi
      Windi Epperson
      Norman OK
    • Kelley Karl
      November 16, 2017 at 10:37 AM
      Hey ,
      Thank you so much for your reply.Ā  It got me thinking about how this is an EFT payment to us and I found the Deposit EFT option on the Bank Deposit entry screen.Ā  It shows up there!Ā  Problem solved!
      Kelley Karl?
      Kelley Karl
      Golden CO
The discussion ‘Deposit in GL but not Check Register’ is closed to new replies.
