Defualting comment ID to specific orders automatically
  • Defualting comment ID to specific orders automatically
    Posted by DSC Communities on April 24, 2017 at 10:50 am
    • Jennifer Combs
      April 24, 2017 at 10:50 AM
      Hello all,
      I was just wondering if there was a way to set it up so that any order that comes in for a specific customer will auto default to have a particular comment ID associated with the order.Ā  Several of our customers have comments that only pertain to them…it would be niceĀ if it could beĀ set up so that the user wouldn’t have to 1. remember to pull in a comment and 2. to remember which comment to use.
      Jen
      Jennifer Combs
      Lohmann Technologies
      Hebron KY
    • Matthew Arp
      April 24, 2017 at 11:07 AM
      There is not a mechanism for this in GP that I have seen.
      Depending on your technical level this would be a pretty easy customization, or should be inexpensive to get a consultant.
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Beat Bucher
      April 25, 2017 at 9:22 AM
      Hi Jennifer,
      As Matt said, nothing out-of-the-box exists.. but this should be something fairly easy to achieve, even with GP Power Tools auto-triggers.. as long as your list of customers is not too long (even then, it could passed as a parameter possibly).
      The trick would probably to have a custom list that would help matching the Customer to the CommentID.
      Beat Bucher
      Montreal QC/Canada
      +1-514-489-4267
      GP2013R2 / MR2012 CU14
    • Blair Christensen
      April 25, 2017 at 6:25 PM
      Purely from a database perspective, you could achieve this using a database trigger.Ā  As we are talking about Dynamics GP, there are already systemic triggers for every transaction in the database and you can get into a mess quickly with multiple triggers firing off the same action (insert into a table).Ā  I’d contact your partner/reseller to ask them if they do custom modifications, as they might be able to tweak the entry window itself to populate the field just prior to saving, eliminating the need for trigger work.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Windi Epperson
      April 26, 2017 at 1:16 PM
      Jen,
      Another option would be to use Word Templates for your invoices.Ā  You can create a different template for each customer so you could add the verbiage you need directly on the template and not need to use the Comment ID at all.
      Windi
      Windi Epperson
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 Ext 102
    DSC Communities replied 8 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Defualting comment ID to specific orders automatically’ is closed to new replies.
