Date Ranges?
  • Date Ranges?
    Posted by DSC Communities on May 4, 2017 at 3:51 pm
    • Trish Robertson
      May 4, 2017 at 3:51 PM
      Is it possible to set a range for the document dates that can be used in Great Plains?
      For example, some payables documents have been entered with a document date listing a year of 2106 and other future dated items. This causes an issue on the AP aging. It is a manual date that is entered by AP in the transaction entry screen in the Purchasing Module. Is it possible to limit this date so they cannot date things so far in the future? Or to create some kind of prompt that says “this date is in a future period. Are you sure you would like to proceed?” – this way they are having to double check their work?
      Trish Robertson
      Helpdesk Supervisor
      CFRLTD
      Greenville SC
    • Matthew Arp
      May 4, 2017 at 4:18 PM
      Unfortunately no, your best bet would be a VBA customization or a .NET AddIn (the latter would be the recommended). This does sounds like an excellent idea for MS Connect though!
      Matthew Arp
      Business Systems Developer
      Hunton Group
      Houston TX
    • Charles Allen
      May 5, 2017 at 2:28 AM
      Trish,
      Install the Professional Services Tools Library.
      One of the options is called Doc Date Verify. It will only allow you to enter dates that are set up in Fiscal Period Setup.
      Using Doc Date Verify
      When Doc Date Verify is activated, and a document date is entered, a check will be
      performed to determine whether the document date is in a valid fiscal period or if
      the fiscal period is closed.
      • If the date does not fall within a valid fiscal period, a message will be displayed
      and the user will not be allowed to continue until the date is in a valid period.
      • If the Document Date falls within a period that is closed, a message will be
      displayed that will allow the user to correct the date or continue on leaving the
      date.
      Charles Allen
      Senior Managing Consultant | BKD, LLP
      BKD Technologies
      Office 713.499.4629
      Cell 713.494.2104
      experience-bkd-thoughtware
      ****** BKD, LLP Internet Email Confidentiality Footer ******
      Privileged/Confidential Information may be contained
      in this message. If you are not the addressee indicated in
      this message (or responsible for delivery of the message
      to such person), you may not copy or deliver this message to
      anyone. In such case, you should destroy this message, and
      notify us immediately. If you or your employer do not consent
      to Internet email messages of this kind, please advise us
      immediately. Opinions, conclusions and other information
      expressed in this message are not given or endorsed by my
      firm or employer unless otherwise indicated by an authorized
      representative independent of this message.
      Any tax advice contained in the body of this email was not
      intended or written to be used, and cannot be used, by the
      recipient for the purpose of avoiding penalties that may be
      imposed under the Internal Revenue Code or applicable state
      or local tax law provisions.
      These discussions and conclusions are based on the facts
      as stated and existing authorities as of the date of this
      email. Our advice could change as a result of changes in the
      applicable laws and regulations. We are under no obligation
      to update this information if such changes occur. Our advice
      is based on your unique facts and circumstances as you
      communicated them to us and should not be used or relied
      on by anyone else.
      ——Original Message——
      Trish Robertson
      Helpdesk Supervisor
      CFRLTD
      Greenville SC
    • Beat Bucher
      May 5, 2017 at 9:47 AM
      Hi Trish,
      Charles pointed you in the right direction.
      However, read this thread carefully, as there are some considerations involved:
      https://www.gpug.com/communities/community-home/digestviewer/viewthread?MessageKey=22e8757f-fb62-4c62-8609-022819c8e518&CommunityKey=4754a624-39c5-4458-8105-02b65a7e929e&tab=digestviewer#bm22e8757f-fb62-4c62-8609-022819c8e518#bm0
      If you’re not sure about how to do it, ask your partner.. and do a quick search here on GPUG forum about ‘PSTL doc date verify’.. I’m sure you’ll find plenty of hints.
      Beat Bucher
      Montreal QC/Canada
      +1-514-489-4267
      GP2013R2 / MR2012 CU14
    • Loan Nguyen
      May 6, 2017 at 8:27 PM
      When you’re running AP Aging report, it’s better to choose GL Posting Date not by Document Date for Select Transactions For Report Using:
      To minimize the wrong date being entered, you could require AP staff to run edit list and then check and correct any wrong dates.
      Hope that helps.
      Loan Nguyen
      Loan Nguyen
      XLN Accounting Solutions
      Westminster CA
