Checkbook ID
  • Checkbook ID
    Posted by Shari Bruno on June 21, 2018 at 12:57 pm
    • Shari Bruno
      June 21, 2018 at 12:57 PM
      Greetings!
      I am assuming that a Checkbook ID, like a Vendor ID cannot be changed once it’s saved. I just discovered that one of our offices began using a Checkbook ID of “Test” for live transactions. I know it doesn’t hurt anything, it just looks odd. Is there anything in the PSTL that combines Checkbook IDs the same way it combines Customer IDs, and Vendor IDs?
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Kyle Malone, CPA
      June 21, 2018 at 10:31 PM
      Hi Shari,
      There is a ‘Checkbook Modifier’ option under PSTL>>Financial Tools.Ā  We’ve used it to modify checkbook IDs in the past and works as intended.Ā  There is no checkbook combiner tool that I’m aware of.Ā  You’d probably have to go through the process to transfer the balances & outstanding transactions to the new checkbook and then ultimately close out the old checkbook.Ā  Trying to go the SQL route to change everything in the system from old checkbook ID to new would likely prove to be tricky as well considering the checkbook reconciliation process.
      Kyle Malone, CPA
      Dynamics GP Administrator
      CGB Enterprises, Inc.
      Covington, LA
      Kyle.Malone@cgb.com
      985-867-3591
    • Shari Bruno
      June 22, 2018 at 12:31 PM
      ?Thanks , I appreciate the help!?
      Shari Bruno
      Crete, IL
    Shari Bruno replied 7 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Checkbook ID’ is closed to new replies.
