Check Batch Not Pulling Anything Due for Payment
  • Check Batch Not Pulling Anything Due for Payment
    Posted by Pamela Lasiter on April 20, 2018 at 12:09 pm
    • Pamela Lasiter
      April 20, 2018 at 12:09 PM
      ?Our check batch is not pulling anything due.Ā  I also tried using the Smartlist report that pulls current payable due and it is not pulling anything.Ā  We do not have any open check batches and we are having to manual select the vendors we want to pay by pulling the invoice dates of open transactions then creating a batch and manually selecting those that are due.Ā  We have never seen this before and it’s been happening for a week now.Ā  Has anyone encountered this before?
      Pamela Lasiter
      Senior Accountant
      Explorer Pipeline Company
      Tulsa OK
    • Kristen Hosman
      April 20, 2018 at 4:42 PM
      Can you screen shot the Select Checks/Build Payment Batch window after you have your restrictions added?Ā  Also would like to see an invoice entered with the due date.Ā  You can blank out any information you don’t want the world to see.Ā  That will help though to maybe detect what’s going on.
      Kristen Hosman
      Dynamics ERP Consultant
      Briware Solutions Inc.
      Pine CO
    • Windi Epperson
      April 20, 2018 at 5:59 PM
      FYI for everyone since this was an interesting one.Ā  Explorer does their select payment process by checkbook id and it turned out that the checkbook id had been changed on the vendors.Ā  So the select works as it should when the new/wrong checkbook is selected. Ā  We’re thinking the most likely reason for the change as a vendor class roll down.
      Windi Epperson [Designation]
      Advanced Integrators, Inc.
      Norman OK
      405-946-1774 Ext 102
    • Kristen Hosman
      April 20, 2018 at 6:21 PM
      I saw the same thing happen to someone else as well only with Payment Priority.Ā  Thanks for the update on this one!?
      Kristen Hosman
      Pine CO
    • Shari Bruno
      April 23, 2018 at 12:00 PM
      That vendor class roll down is a dangerous thing, and in the time that I’ve been using GP (since 2003) that hasn’t changed. It would be better if the default when changes are made is “no.”
      Shari Bruno
      Accounting Operations Manager
      Bible League International
      Crete, IL
    • Windi Epperson
      April 25, 2018 at 12:19 PM
      An additional update in case anyone searches for this in the future.Ā  This ended up actually being a Mekorma related issue.Ā  A new Mekorma feature got triggered and was causing the problem.Ā  There is more to it then this, but just know if you run into the issue and use Mekorma, keep that in mind. šŸ™‚
      Windi
      Norman OK
    Pamela Lasiter replied 8 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Check Batch Not Pulling Anything Due for Payment’ is closed to new replies.
