Changing Terms Discount
  • Changing Terms Discount
    Posted by Unknown Member on April 10, 2018 at 1:16 pm
    • David Kelsey
      April 10, 2018 at 1:16 PM
      Can someone tell me if you can change the payment terms on an open A/P invoice.Ā  We are trying to take advantage of some discounts being offered but the vouchers had already been entered and we can’t find a way to get the system to take the discount on invoices already posted under a different terms code. Ā  I did see where due dates and discount dates can be changed but not the terms code.Ā  Thanks
      David Kelsey
      The Schaefer Group, Inc.
      Dayton OH
      April 10, 2018 at 2:41 PM
      ?Hi
      You cannot change the terms of any given invoice.Ā  You CAN change the due date in Edit Transaction Information, but that is all.Ā  If you are trying to capture discounts you will need to void and re-enter the transactions.
      If you have way too many invoices to do that for (I mean over 100) then you should contact your partner or dba and have someone generate a script to change the terms in the database.
      However, they’ll need to be careful.Ā  I’ve done this for one of my clients and there are a number of fields that will need to be updated for this to be successful.Ā  I do NOT recommend this approach, only letting you know that if you go down this path, make sure that the staff making the change is very knowledgeable in the GP database and data flow areas.
      Sorry it’s not better news.?
      Kindest Regards,
      Jo deRuiter
      “That GP Red Head”
      Milwaukee, WI
      770-906-4504 (Cell)
    • Leslie Vail
      April 10, 2018 at 5:11 PM
      If you have many of these to modify, I suggest you use the ‘mail-merge’ macro to change all of them in the Edit Payables Transaction entry window.
      Leslie
      Leslie Vail
      DALLAS TX
      leslievail@earthlink.net 972-814-8550
    Unknown Member replied 7 years, 12 months ago 1 Member · 0 Replies
The discussion ‘Changing Terms Discount’ is closed to new replies.
